07' SS rims on a 03' SS??
Old Mar 22, 2009 | 01:25 AM
stan409's Avatar
Default 07' SS rims on a 03' SS??
I just bought a 03 monte ss. I really like the look of the 18" 06-07 ss rims and i would like to put them on my car. I know they are different bolt patterens. But i here a bunch of mixed reviews to weather or not they will fit. So will they fit? Do i need adapters or hubcentric rings? If so what size? What size tires should i run? I was thinkin 245/45-18. Also my car has the skate board style spoiler and i want to change it to the nascar style, i've heard that the 06-07 style will work. Is it a direct bolt on? Where can i find one? Thank you.
Old Mar 22, 2009 | 05:18 PM
06_MCSS's Avatar
Stan
I would say that the wheels would fit. I just sold my stock wheels off of a 2006 MC SS to a guy that put them on a 2002 impala. Also, my winter wheels are from a 2004 impala. So, I think all GM FWD cars use the standard 5 x 115 bolt pattern and 40mm offset (at least over the last couple years).
If you do not believe me, check out tirerack.com, they have good info on stock wheel sizes.
Old Mar 22, 2009 | 06:42 PM
ramos87ss's Avatar
I have seen an 03 pace car on autotrader with the 06-07 SS style wheels, so obviously it can be done.
Old Mar 22, 2009 | 08:28 PM
ryan2002ls's Avatar
This should answer the question about the new wheels:
https://montecarloforum.com/forum/sh...ad.php?t=12664
Old Mar 23, 2009 | 09:21 AM
RickAKATed10's Avatar
Photobucket
Fits without a hitch. Searching for the answer is key here!
Old Mar 23, 2009 | 11:33 AM
both are direct bolt ons
Old Mar 23, 2009 | 08:21 PM
I've heard that the 06/07 spoilers are a different bolt pattern than the 2000-2005. You may have to drill new holes.
Not 100% on this though, since I've never seen the bolt pattern of the 06/07.
Old Mar 24, 2009 | 06:05 PM
stan409's Avatar
Thumbs up
Thank you everyone.
Old Mar 24, 2009 | 07:35 PM
mksiler's Avatar
I put SS wheels on my 98 GTP. The wheels Scrub a little when turn the wheels at max but no big issue!!! I just put a pic up on the wheels section.
Old Mar 24, 2009 | 08:23 PM
inssanity21's Avatar
i did take a peak at the spoilers and they do seem to be the same. you might have to ream the holes a bit and put some silicone with the bolts to prevent any leaks but thats it.
Floydcarlo
May 13, 2014 09:23 AM
05MonteLS
Mar 25, 2014 09:28 PM
Randdady
Mar 23, 2011 08:16 AM
05MonteLS
Dec 3, 2010 09:00 AM
irulesoha
Sep 21, 2010 10:08 AM
