06-08 Wheels Rubbing on 01 SS
Old Mar 30, 2011 | 08:29 AM
TheMonteMan's Avatar
how close is it? couldnt you just run a thin wheel spacer?
Old Mar 30, 2011 | 01:22 PM
x2 on this, a thin one wouldnt look any different for spacing really between the front and rear
Old Mar 30, 2011 | 03:48 PM
NovaSS369's Avatar
They bolt up tight when the car is jacked up and they dont hit the strut tower at all. Butttt when I drop the jack the bottom of the strut rests on top of the tires. So I don't think a spacer is what I need exactly...
Old Mar 31, 2011 | 11:00 AM
are your springs and struts totally worn out?
Old Mar 31, 2011 | 02:00 PM
dougg's Avatar
From what I read on other forums you can get the KYB GR2 below. Note you need the one " w/ Special Handling Suspension;" i.e. FFE4 these will allow you to fit the taller tires. Also different valving.. I have not installed this so it might be best to call KYB to confirm.
kyboutlet.com
GR2 Kit for Chevrolet Monte Carlo (2004-2007)
$281.38 There are no notes for your vehicle (Chevrolet Monte Carlo 2005) Add to Cart
Front and Rear
Fits: 2004-2007 Chevrolet Monte Carlo
Note: w/ Special Handling Suspension;
Includes: 339015 339015 339148 339148
Old Mar 31, 2011 | 02:21 PM
NovaSS369's Avatar
Definitely doesn't seem like it. It still rides great and doesn't sag when I put weight in the trunk or back seat...
Old Mar 31, 2011 | 02:50 PM
LuSe4's Avatar
Does this not sound right to anyone else? The relationship between the tire and the strut shouldn't change when weight is applied, unless i am not understanding what is actually happening.
Old Mar 31, 2011 | 04:13 PM
the bottom of the strut plate shouldn't really move at all when lowered..
Old Mar 31, 2011 | 11:05 PM
NovaSS369's Avatar
Okay. The passenger side doesn't move at all when I do this. I can bolt the wheel and tire to the hub and have about a quarter to 3/8 of an inch of space. On the drivers side it starts that way but once I release the jack it is sitting on top of the tire. What could this be? Bad strut??
Old Apr 1, 2011 | 08:14 AM
sounds odd to me. you never had a problem with your old wheels?
