mammoth soaxins 2002 monte carlo ss
Old Dec 21, 2013 | 09:03 PM
soaxin's Avatar
Doing retrofits! Will have pics when done
Old Dec 21, 2013 | 09:51 PM
dbaldwin's Avatar
Let me know what it would cost if your willing to do it for someone. I'm excited to see it, and btw, my subs and amp turned out beastly!
Old Dec 22, 2013 | 09:14 PM
soaxin's Avatar
I got them done today but I only have pics of the one because I rand out if daylight. Ill get more pictures tomorrow.
Old Dec 22, 2013 | 10:38 PM
dbaldwin's Avatar
That is sick dude!
Old Dec 22, 2013 | 10:48 PM
Interesting setup! Got pics of how you did it?
Old Dec 23, 2013 | 09:12 AM
soaxin's Avatar
Unfortunately no. Its actually very simple. The only issue is you can't go back to stock because the housing has to be modified. Basically you cut out everything that holds the stock bulb in place so you can get a snug flush fit with the projector.
Old Dec 23, 2013 | 09:44 AM
What glue are you using to re-assemble the head light? And what method did you use to pull the headlight apart?
Old Dec 23, 2013 | 01:57 PM
soaxin's Avatar
I put the headlights in the oven to soften the glue then I just use a flat head screwdriver to pry the lenses off.
most of the I just reheat the housing and reseal with the original glue. If the original glue is in bad shape I use butyl rubber glue.
Old Dec 23, 2013 | 06:51 PM
Sweet set up
Old Dec 23, 2013 | 08:05 PM
soaxin's Avatar
Thanks!
