Engine Build: Is a 2600 Stall good enough for this cam?
Old Mar 21, 2021 | 10:51 PM
Terbronco7's Avatar
Default Is a 2600 Stall good enough for this cam?
Old Apr 12, 2021 | 02:03 PM
I dont think we've got a lot of big block modders on this forum. You're probably best off reaching out to the manufacturer of the cam to discuss your application.
They should have all of the info on the ideal situation it was designed for to determine how close youre proposed setup matches or if they've got another cam that may better suit your needs.
Old Apr 21, 2021 | 05:04 PM
Jeffs02rwdSS's Avatar
Contact a torque converter manufacturer with your cam, engine, tire and final gear spec's. ACC " Boss Hog" is very friendly and provides answers for free over the phone. Usually whatever the cam RPM range is about what the stall would be, guessing a 3000-6500 camshaft would need around a 3000 stall. Good luck
Old May 13, 2021 | 12:32 PM
GrayGhost1951's Avatar
Default Torque Converters
Originally Posted by Terbronco7
Call ATI. Best converters around. That's a pretty mild stick., You won't need a lot of stall.
djhixter
Jan 21, 2014 09:50 PM
gasman
18
Mar 10, 2012 10:27 AM
bama_monte70
Dec 22, 2011 08:11 PM
Burke90
Sep 9, 2009 08:57 PM
Recluse tha Ripper
May 16, 2009 08:58 PM
