Info: engines that I can drop into my Monte Carlo SS and still be able to use the Computer
Pretty much any small block chevy (SBC) engine can be swapped in and still retain all of your emissions equipment, including the computer.
For the computer to continue functioning as it should, all of the sensors on the engine must be retained. Some engines do not have provisions for all of these sensors or emissions functions (such as EGR).
For a 350ci engine swap, a new 350 specific knock sensor and spark control module must be used. The knock sensor is tuned for each block type's specific harmonic range, so using a 305 knock sensor on a 350 block will not work as designed.
Some engines, such as the big block chevy (BBC), and the newer Vortec SBCs require a little more work to retain the emissions equipment.
It is possible to have a new PROM chip made for your ECM to adapt the computer to your new engine setup. Refer to the few ECM chip manufacturers web pages for more information.
Always keep in mind your local emissions laws when swapping engines. Some areas prohibit the changing of the engine. Before you do anything, find out what the requirements are in your area.
wat if emissions isnt a problem with me. i wana do a 350 swap and remove my computer so i can use my edelbrock carb on it. do i have to buy a already carborated 350 or could i use a vortec motor and take off all the sensors and junk..
if you just wanna swap in a 350 and drop the comp, you all u need ie q vac advace dist and a non comp controlled carb ie, holly,edlebrock ect ect or non cc Q jet
Hi, I'm new on here, but I have a question. This is the perfect thread for me, as I'm wondering how hard it would be to put an LT-1 in a G Body? And, either still use the stock ECU, or the one that came with the engine? I would imagine the one from the engine would have to be used (EFI vs CCC). So, how much of a nightmare would this be? Can it be done? And, what about the 'idiot' lights in the dash, and all the power accessories? Aren't they ran off the ECU? And, wouldn't an OBDI engine ('94-'95) be easier than an OBDII engine?
Just wondering if anyone has ever tried doing this before.
Thanks, John
Thanks, John
mike.bayville
Jul 11, 2013 10:16 PM
tridski
May 17, 2010 03:27 PM
