Racing your Monte Raced a guy in your ride? Had that Monte Carlo of yours on the timed track? Tell your story here.
went to the strip today
Old May 11, 2008 | 08:57 AM
v8_Killa's Avatar
Default RE: went to the strip today
the were off and outside temp was around 70 any ideas?
Old May 11, 2008 | 11:25 AM
DeboDaddy's Avatar
Not really. With those 60' times, I would have thought you would've been in the 15.4-15.6 range.
Old May 11, 2008 | 11:43 AM
MonteMadneSS04's Avatar
i ran my 04 ss na at the track about 2 wks ago... ive got cai and exhaust but no tune yet.... my best time was 15.989 @ 86... so ur not far off w/ the tune....thats about the range you should get....
to boost ur times a bit more.... a few suggestions
1) lower your tire pressure on the front wheels about 3-5 lbs... I wouldn't go much lower than that...you have to make sure that the tread contact points with the ground are even so that the tire doesn't bow out or the middle of the tireisnt the only thing in contact w/ the ground.... look at the pic below for a better guide
2) take your engine cover off and lift your hood inbetween runs to cool the engine a bit more
3) if the inspectors let you... take your driver's side headlight out to get better airflow to the cai
4)PRACTICE your launch!!!
Old May 11, 2008 | 06:25 PM
Cowboy6622's Avatar
ORIGINAL: MonteMadneSS04
I trained her well
*sniff sniff* so proud....
Old May 13, 2008 | 05:03 PM
v8_Killa's Avatar
thanks will do and hopefully this weekend will yeld mid 15s
Old May 14, 2008 | 06:08 PM
v8_Killa's Avatar
oh and about the launch i put it around 2000rpms on the light i slowly (but not too slowly) push to 25-27 then punch there is no cherp any ideas and is no cherp good or do i want some cherp
Old May 14, 2008 | 09:00 PM
Cowboy6622's Avatar
unless you got flat out $hit for tires, you should be bale to go full throttle around 15-20... or i'm weaker than you guys
Old May 15, 2008 | 12:16 AM
1WX27's Avatar
hmmm, I'm surprised to find they my 97 Z should be right in there with the 3.8's... even a bit faster in a perfect world. I'm enjoying this thread as a "prep" tool.
DeboDaddy's Avatar
No chirp is what I've been trying to get at the strip, but I haven't achieved it yet.
Some will argue that a little bit of tire spin to keep the RPM's up on low horsepower applications is actually a good thing, and if it hooks and bogs that it will run slower. Well, tell me that when I can launch my car at ~2300rpm without blowing the tires off of it.
Old May 15, 2008 | 06:25 AM
Cowboy6622's Avatar
i've heard that chrip doesn't really hurt you... it's a constant spin that does.
