Racing your Monte Raced a guy in your ride? Had that Monte Carlo of yours on the timed track? Tell your story here.
A GOOD LAUNCH
Old Jan 23, 2008 | 11:50 PM
3800monte's Avatar
Default A GOOD LAUNCH
whats a good way to launch my ss for the best times
Old Jan 24, 2008 | 06:37 AM
Cowboy6622's Avatar
Default RE: A GOOD LAUNCH
hold the RPM's around one thousand and just ease into it.
Old Jan 24, 2008 | 08:10 AM
1977Monte's Avatar
Practice... start from off idle and work your way up in launch rpm.. you'll find the best rpm eventually that provides a launch without tirespin, but gets into the powerband quickly.. or buy sticky tires lol
Old Jan 24, 2008 | 12:18 PM
mickey's Avatar
rocket launchers just load it up and pull the cord hang on for the ride!!
beign front wheel drive i have to say i honsetly never tried it at a track. i have done it on the road etc... but not to wher ei had to worry about being consitant on it
Old Jan 24, 2008 | 05:40 PM
lav74's Avatar
1800-2200rpm is the best for the 3800/4t65E in stock form or lightly modded on street tires.
If you're at the track launching, do not go through the burnout box if you have street tires. Go around it, stomp the gas for a split second just to make the tires spin off the little rocks and any dirt that might get in the way of traction. Pull up to the line, hold your brake, when the last light hits before the green, let go of the brake, and take 1 full second to "ease" into full throttle. You will need to be very conservative at first, since the first urge is to mash the gas, and go ***** out. Be patient, and practice.
If it's on the streets, go by the seat of your pants as to what pulls you forward best. Usually, it's the same rule... take 1 second to get to full throttle, depending on the conditions.
Old Jan 24, 2008 | 06:37 PM
03SS's Avatar
I launch around 3000 and ease into the gas but I have high performance tires
Old Jan 24, 2008 | 07:34 PM
86Ls's Avatar
What's the best way to launch?
Well it depends on a couple things.
1. Car and modds done to it as for as CAI, U-bend ect.
2. Tires on your car. Are they aftermarket or stock?
3. Track. Each track is different and set fourth a list of difficulties.
Seems like everyone likes between 1 and 2 grand. Depends on a combo of the 3. I would recomend lower tire pressure to about 20lbs? maybe a little more or less. A guy at the track as a 04 SS s/c and he winds his up to I'd say about 2000+ and eases into the gas. But then again he's got aftermarket tires along with a lot of experience.
Your best bet is to just go out there with a general ballpark and adjust.
Good Luck
Old Feb 21, 2008 | 05:01 PM
v8_Killa's Avatar
i live by the 1500 rpm spot its just right no tire spin and enough power to get to finish a winner
Jul 8, 2012 08:27 AM
Jun 17, 2011 08:34 AM
May 13, 2011 06:51 AM
knightfan26917
Feb 27, 2011 02:03 AM
BeachBumMike
Feb 18, 2008 11:07 PM
