Racing your Monte Raced a guy in your ride? Had that Monte Carlo of yours on the timed track? Tell your story here.
Engine swap
Old Dec 15, 2015 | 12:46 AM
Ricky_rozzayy's Avatar
Default Engine swap
Can some list the engines I could put in my 2002 Monte Carlo ss that everything would link up correctly and so I won't have to give a drivetrain swap or anything and I would prefer the same transmission but that's prob not gonna happen lol
Old Dec 15, 2015 | 12:32 PM
ohara's Avatar
A 3800 Series II either naturally aspirated which is a direct drop in, or you can go supercharged 3800 Series II but you will need wiring harness, new PCM or have yours tuned, you can keep the same transmission but will need it tuned to the gear ratio as the supercharged engines have a different ratio.
Old Dec 15, 2015 | 03:11 PM
turbo monte's Avatar
^that
Old Dec 15, 2015 | 04:00 PM
So no type of ls engine will fit
Old Dec 15, 2015 | 08:31 PM
There is a guy that swapped in a ls4 but it's a lot of work
Old Dec 16, 2015 | 10:25 PM
nitehawkjcb's Avatar
Oh I'm sure you can make an LS motor fit. A lot of work either way. LS4 is FWD, but a lot of wiring I'm sure. Otherwise, there's a lotta learning to be done about making a car RWD.
Old Dec 23, 2015 | 05:22 AM
fatfig's Avatar
keep me posted if you do it....
