Racing your Monte Raced a guy in your ride? Had that Monte Carlo of yours on the timed track? Tell your story here.
Bone Stock 2000 SS
Old Jun 29, 2008 | 03:48 PM
warrioralumni08's Avatar
Default Bone Stock 2000 SS
Hello everyone I am new to MCF and am glad to have joined! Well, I have a 2000 Monte Carlo SS and its sage green with about 117000 miles and I have had the car for about 2 1/2 years and have never took it to the track but I plan on to next weekend. So, my questions would be what 1/4 mile times should I be expecting and at what rpm's would I want to launch at? Oh and I plan on running with 1/4 tank of gas or less and no spare or jack.
Old Jun 29, 2008 | 04:30 PM
bfurches's Avatar
Default RE: Bone Stock 2000 SS
Im gunna guess a stock ss will run 16.2
Old Jun 29, 2008 | 05:12 PM
v8_Killa's Avatar
yea 16.1-16.2 is your target at stock dont forget to: 1. remove front head light (takes like 45 sec to do) 2. lower the psi in your front wheels 3. launch around 2000 rpm 4. drop the gas to about 1/8th of a tank 5. and have fun!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 29, 2008 | 06:43 PM
Ok thanx but I have some more questions now. What is the point in removing both headlights? and I would lower the psi in my front wheels to increase grip right? traction should be off right? Also is it possible to get it in the 15.9's?...Other suggestions anyone would want to throw at me to try and get the best time I can?
Old Jun 29, 2008 | 08:30 PM
Cowboy6622's Avatar
you don't need to remove both... just the drivers side. this makes for "headlight ram air" as we drag racers like to call it... the air is picked up right behind that headlight so removing it puts more air to the engine... i pick up like .05 of a second by doing that . seriously, my best time was without a headlight... .015 seconds faster than with it. however, they were different days... the day i removed my headlight was MUCH warmer than the day i ran without it.
Old Jun 29, 2008 | 09:07 PM
Sweet!! Thanks for that info , should help it then. Well, what if I take out my air filter out down at the track, you think it would improve time also because its basically the same concept with the headlight ram air. No headlight+ No air filter=More air....or is that a big no no?
Old Jun 29, 2008 | 09:11 PM
bfurches's Avatar
on street tires, you dont want to drop pressure much more than 25psi...lower than that is just going to tear up your tires...
launch around 1800-2100, but dont go gun-ho out of the hole. feather the throttle while you spin until you feel her bite then lean into it hard.
Jack up the rear tire pressure. (it wont do much...but it will help the car from squating on the tire. suspension will still squat, but more ire pressure wont let you sag to the rim under load)
...oh and make SURE you drive around the burnout box. you DONT want to get those street tires wet. As you pull up to the line, giv the throttle a quick wack just to clean the tires off and get ready to go.
Have fun dude.
Old Jun 30, 2008 | 03:04 AM
Alrighty I suppose this is all the info I need, thanks everyone! but if there is anything else anyone would like to tell me feel free!! Hopefully will have pics of my car up pretty soon.
Old Jun 30, 2008 | 06:19 AM
1WX27's Avatar
Do NOT remove your air filter. You can get a K&N drop in or get a new intake, but for the love of your engine internals, do not remove the air filter. More airflow + no air filtration is a bad idea. Anything you car sucks through the intake will go right through to the engine( well, I suppose it could get caught in the honeycomb, but I wouldn't leave it to chance)
Enjoy the race.
Old Jun 30, 2008 | 02:32 PM
Yea I figured it would probably suck in all the stuff if i removed the air filter , so i decided not to do it, hmm I think I already have a k&n drop in air filter , also and exhaust system...=] but hey thats still basically stock right.
