PRIVATE Wanted Classifieds Looking for something? Tell us!
Wanted: L36 Passenger Side Engine Bracket
Old 07-01-2012 | 06:17 PM
brendan127's Avatar
Default L36 Passenger Side Engine Bracket
My bracket got a hairline crack in it, I'd like one for the same price zzperformance had them.
GM ACDelco - Used L36 Engine Passenger Side Bracket #ZZ-USED-L36PSBRKT
Old 07-01-2012 | 06:23 PM
01 Monte SS's Avatar
When mine broke I upgraded to the cast iron mount / coil pack mount found on GTPs and most L67s I believe? A good upgrade that you definitely won't break. Also just a good idea if you plan to mod your Monte If you contact ZZP they may have a few of those that they'd sell for the same price as the aluminum mount.
Old 07-01-2012 | 11:40 PM
brendan127's Avatar
Are they shaped differently?
Old 07-01-2012 | 11:46 PM
Replaces the coil pack bracket I believe. Looks like this:
Old 07-03-2012 | 01:38 AM
turbo monte's Avatar
I highly recommended the cast iron bracket as well. It will never break and they sale for around $35. Your icm and coil packs will swap right over on it no problem.
01 monte ss if I remember correct wasn't I the 1 that told you about doing this? Glad to see you are!
Old 07-03-2012 | 09:28 AM
Yeah! Thanks again!
Old 07-03-2012 | 02:07 PM
brendan127's Avatar
That looks nothing like the one I need.
Old 07-03-2012 | 03:09 PM
it looks nothing like it but it will most def work and is alot stronger.
you are talking about the aluminum mount on the passenger side beside the coil packs correct?
Old 07-03-2012 | 04:30 PM
Trust me.. this is what you need. (it mounts to the side of the engine instead of on top like the little aluminum mount) If you replace with aluminum you risk over-tightening and just breaking it again. If you pick up a cast iron mount like I pictured above, you'll thank me later if you plan on modding or just want that extra security.
And, if Turbo Monte uses the cast iron mount and has no issues, you will most definitely be fine
Old 07-04-2012 | 06:19 PM
brendan127's Avatar
Yeah but will I have to do anything extra to put it on? My brother got a cast iron one for his series iii and we couldn't figure out how to put it on.
