SLP Grille. Help Please?
Old Jul 29, 2011 | 04:05 PM
codym0914's Avatar
Default SLP Grille. Help Please?
First off, I'm a new member to this site but I been coming here for several "How To's" on my Monte. But I need help on this one. I purchased a SLP grille for my 02 Monte Carlo SS. And I see all these post on what they look like but I dont see any posts on how to actually put it on. So can someone please explain how to put on the grille? Pictures will be helpful. Thanks in advance.
Old Jul 29, 2011 | 05:08 PM
Using dental floss and a cloth wrapped screw driver remove the knight's crest.
Clean up the area.
Put emblem adhesive on the SLP grille, line up, and stick!
Old Jul 29, 2011 | 05:11 PM
you have to remove the knights crest, use some floss, double it up and use a saw like movement behind it, there are 2 posts on the back of the crest so use the floss on the top and bottom until you hit each of the posts and then pull and it will come off
then you will probably want to paint or put some vinyl behind where the slp grille will go, your best bet may be to plasti-dip it, this way it's removable incase you ever decide to sell it
then to mount the grille you just use double sided tape and you're done!
Old Jul 29, 2011 | 07:12 PM
codym0914's Avatar
thanks guys, thats all i needed to know. i appreciate the help
Darik Fine
Nov 7, 2013 07:54 AM
Franks 03SS
Aug 4, 2011 12:36 PM
MyIntimidator
Jan 4, 2008 01:31 PM
tlip06
Nov 15, 2007 11:13 PM
MyIntimidator
Nov 10, 2007 08:45 PM
