Question on HID's for mrl390, Matt or anyone
Old Feb 12, 2011 | 08:42 PM
dynomonte's Avatar
Default Question on HID's for mrl390, Matt or anyone
Hey Matt, I saw in a write up that you said you bought HID's from DDM Tuning and I just had a couple questions for you. Did you just buy the basic Raptor HID kit ($30) or did you get some of the add-ons? The basic is the two ballasts and two bulbs. The add-ons I wasn't sure if I needed are the HID harness and the mounting brackets. I will be putting these into a 1996 Monte Carlo.
Also, how are the lights working out for you...any problems since the original purchase? I like the fact that these have a lifetime warranty!
Anybody can field this question, I just knew Matt purchased the same ones I'm looking at. Nothing better than first hand experience.
Thank you!
Old Feb 12, 2011 | 08:51 PM
bonang's Avatar
From my experience the best way to install HIDS is using the the DRL relay harness and pull the constant power from the Battery and not the factory wiring.
I have my highs, lows, and fogs wired with relays, only pulling the signal from factory wiring.
Old Feb 14, 2011 | 12:43 AM
dynomonte's Avatar
I just went ahead and purchased the hid harness just in-case if I would end up needing it...it was only $12. Thanks for the tip though.
Old Feb 14, 2011 | 01:46 AM
you wont really need the harness to make them work, it should work directly out of the box, did you get the 35w or 55w? with 55w it might be a good idea, but either way you should be safe on stock wiring
Old Feb 14, 2011 | 11:06 PM
dynomonte's Avatar
I went with the 35w because I wasn't sure if the 55w would be too hot for the housing so I just played it safe. The 35's will be way better than my stock bulbs anyways. Thanks for the insight Trewyn.
Old Feb 15, 2011 | 10:49 AM
no problem, if you have the harness for them though, you might as well use it, it can only help, but going without it will not hurt anything.
Old Mar 1, 2011 | 09:00 PM
dynomonte's Avatar
Well, I finally got some time to install the HID's today and they look and work great! I didn't end up using the harness, it seemed like a lot of extra work to hook up something that MIGHT help. I would have had to take off a lot of pieces to be able to run all the wiring the way I would want it. And I was thinking the more pieces I install increases the odds that I'll have to replace something down the road.
Thanks for all the tips!
mrl390
Nov 8, 2009 05:34 PM
mrl390
43
Oct 26, 2009 05:47 PM
scc24540
May 10, 2008 09:21 PM
BLACK ATTACK
Dec 5, 2007 01:08 PM
anabolicsman
Oct 9, 2006 03:40 AM
