Light covers
Old Dec 23, 2010 | 10:01 AM
Jparks's Avatar
haha i just watched the Youtube video i was about to post it myself
Old Dec 23, 2010 | 12:05 PM
Jparks's Avatar
I just went around to a bunch of shops in Windsor/LaSalle and no one had in Stock or even knew what VHT was i guess im gunna have to order it online i was so pumped to do it today.
Old Dec 23, 2010 | 04:16 PM
you dont need to sand them, clean them good with rubbing alcohol then water to get all the alcohol off, make sure they're dry and clean and spray the vht on lightly first so it doesn't run. the stuff will get thick quick so make sure not to get it too dark.
Old Dec 23, 2010 | 06:13 PM
7801MonteMan's Avatar
Two things...I don't agree with the whole no sanding comment. Maybe it's because I am used to automotive grades of paint but never in any of my training and certification tests have I have heard of when you are spraying any coating on surface for the first coat no sanding. Even going from primer coats to a color coat you sand. Now once the first coat of base has been layed you don't sand and all you do at most is use a tack cloth to remove any dibris of any sort.
Also I personally would not use water after alcohol. Once the alcohol dries you're fine and good to go. Maybe distilled water if you really feel you need to. But I would not recommend doing so. I would recommend once its sanded with 4/5hundred grit sand paper use a good wax and grease remover. This and a tack cloth is all you need.
Does the directions say to not sand and to use water? This just goes against everything I have been tought. Not saying your wrong or not to do it correctly by any means.
Old Dec 23, 2010 | 11:41 PM
Jparks's Avatar
i did my reverse lights and brake light and they turned out pretty darn good, i plan on doing my tail lights tomorrow well it's 12:30 so today will let you all know how it went, oh i just followed a youtube instruction it was actually really good i believe someone posted the same ones i watched just before i was about to their pretty detailed and helped me out a lot and got a great result.
Old Dec 23, 2010 | 11:46 PM
yeah thats fine, i'm not a pro at it by any means, but that's just how i've found it works best for me and i've done a few sets with good results in the beginning and the end. but hey if your way works for you thats all that matters right?
Old Dec 24, 2010 | 12:09 AM
jarheadbobandmax's Avatar
Photobucket
sand b4 paint always if you want it to hold....alcohol no water,, lint free towel or blow dry and keep the finger oils away,,,
this works for me and I'm not a pro either...just watch others and listen..hate having to do things twice which is why I love the threads on the forums where the paint and body guys can chime in...
hotrodharley
Nov 15, 2013 11:37 AM
gohawk72
Oct 2, 2009 02:14 PM
mikeymontecarlo
May 1, 2008 02:41 PM
zipsayain
Jul 17, 2006 09:19 AM
kissmyss03
Jul 15, 2005 11:25 PM
