How To Mount Front Bumper License Plate Filler?
Old Mar 24, 2014 | 03:13 PM
michelob's Avatar
Default How To Mount Front Bumper License Plate Filler?
So I've decided to order a front bumper license plate filler instead of having my bumper repaired. I have a triangular crack in it at the upper left corner extending down to the bottom left right where the license plate would mount. If I order a filler am I going to be able to mount it? How do these fillers mount? I don't want to order something and then realize that because of the way my bumper is cracked in the license plate area that the filler will not work.
Thanks guys.
Old Mar 24, 2014 | 03:15 PM
The top has tabs that go into the bumper, and then there are 2 screws on the bottom.
Old Mar 24, 2014 | 03:26 PM
michelob's Avatar
So at the top I noticed there is like a half inch "vent" or opening with a couple larger areas on the very ends of that vent or opening would that be where the "tabs" go?
Also on the bottom of the bumper cover I noticed what almost what looks like a couple "pilot" holes started in the bumper (2 on each side) would that be where it gets screwed to the bumper cover by chance?
So basically if I want to mount a bumper filler and there are not holes to do so I will actually have to drill into the bumper cover correct?
Old Mar 24, 2014 | 03:29 PM
That would be completely correct.
You'll know more clearly once you have the cover in your hands.
Old Mar 24, 2014 | 03:35 PM
michelob's Avatar
OK I might be able to make that work then.
Thanks for the help!!!
Old Mar 24, 2014 | 03:55 PM
michelob's Avatar
OK just snagged one on Ebay. I'll have to repaint it but dude only wanted $43.00 for it which is over half the price off of what it is anywhere else.
gdixonjr
Jan 3, 2016 11:37 AM
Nova1585
Nov 14, 2011 05:37 AM
bnahum
Aug 27, 2011 11:15 AM
wildnorth29
Oct 7, 2009 12:20 AM
