Ground Clearance Question
Old Nov 1, 2016 | 02:22 AM
96z34man's Avatar
Default Ground Clearance Question
i know my car is supposed to have the HS ground effects, but it looks much further off the ground than an 00-05 SS. The only site I could find that gives the spec for ground clearance says 5.9, and on the earlier SS, it says 6.3, but I suspect that's without the HS package.
Does anyone who actually has a 00-05 HS know your ground clearance? (I'll never see one in this county again to measure it.) Am I hallucinating, or is this just extra height caused by the 18's?
Old Nov 13, 2016 | 10:03 AM
haha chad's Avatar
What is the tire profile for the 18,s?
Old Nov 15, 2016 | 04:30 PM
96z34man's Avatar
50, which is the OEM size. They're Eagle RSAs, which I think are the OEM tires.
Old Nov 24, 2016 | 08:02 PM
The 18s are a little taller. Exact specs vary by manufacturer, but they should be about 1/2" taller than the 16s or 17s on the lower models.
Going to a 45 profile would reduce that to about 1/4" shorter than the 16/17 height, but I remember you didn't like the low profile look (not that a 45 is really a low profile tire in modern sizes, but it is shorter than a 50).
Switching to some 15s or 16s give you more room to reduce height and still leave plenty of sidewall.
