6th Gen ('00-'05): Fuel door replacement
Old 07-23-2014 | 01:04 PM
Chevy Kid's Avatar
Originally Posted by Brboon86
Exactly what he said. My method was by taking off the plastic around the fuel neck as it is much less work then removing the wheel well liner in my opinion.
The bolts are kind of tricky to get a socket wrench on, and if they are rusted be very careful about stripping them.
I stripped the top one of mine during the process and had to use a Dremel tool to cut the end off of it( being extremely careful with sparks near a gas cap ).
When you take the plastic off the fuel neck theres only those 3 bolts holding it in right? And Thanks Guys I appreciate it
Old 07-23-2014 | 04:01 PM
Franks 03SS's Avatar
2011 Monte Of The Year
Yup, just need to wiggle it out
Old 08-25-2014 | 09:45 AM
WImonteman's Avatar
so there are bolts holding it on not rivets?
Old 08-26-2014 | 10:13 AM
Chevy Kid's Avatar
[QUOTE=WImonteman;627971]so there are bolts holding it on not rivetsUOTE]
There are three bolts you have to remove from the plastic piece that goes around the fuel neck then that same plastic piece has two lips holding it in place. once you remove it you'll see the two bolts holding the fuel door on.
Old 08-26-2014 | 11:31 AM
WImonteman's Avatar
alright awesome cause I need to replace mine also.
Budsjlm
FWD Tech Guides '95-'07
10-29-2015 06:01 PM
Chevy Kid
07-08-2014 09:09 PM
The_Maniac
01-26-2014 06:54 PM
keala
09-14-2007 12:55 AM
fastback4
12-25-2006 01:42 AM
