fog lights for a 2000 Monte Carlo
Old May 1, 2015 | 08:21 AM
Originally Posted by chevykid404
@crazyzach722 could that power wire connect to the fog light switch.
I would imagine you could wire a wire that would be a hot wire to the relay off a factory fog light switch.
Old May 7, 2015 | 03:23 PM
Scott_S's Avatar
Someone correct me if I'm wrong (there's a good chance I am) but I remember reading that the fog switch is a momentary switch and connects to the bcm.
When I found a set of lights and brackets at the JY, I snipped the fog connectors so I could fab my own harness. Unless I'm wrong, if you connect the fogs the stock way(using the bcm), you may need a bcm flash for it to "learn" the fog lights.
I'm going to be installing mine sometime soon. If I remember, I'll do a write up.
Old May 8, 2015 | 04:06 PM
plumbob's Avatar
Disconnecting any component of the lighting system wiring harness will throw a "B" code because the BCM checks for grounds, but once reconnected and returned to normal operation the code will clear. No flash is necessary unless the BCM is disconnected.
Old May 19, 2015 | 05:11 AM
chevykid404's Avatar
I noticed at the junk yard that all the monte's with a 3800 motor had a fog light harness. Does the 3400 motor monte have a fog light harness too? I looked at 8 different cars and 5 of them were 3800 motors. Could I use a harness off a 3400 impala that has fog lights?
Old May 19, 2015 | 05:50 AM
KingWord's Avatar
I don't think the ls's came with fog lights so the most likely wasn't wired for it,but im sure you could grab one of a car that does have a harness and wire it up,but im not too big on electrical stuff,just be careful when you hook stuff up like that,i had separate headlights wired to a switch on my 86 and it caught fir under the dash because the wire would get really hot for some reason,not too sure
Old Jun 3, 2015 | 06:46 PM
Okay so I noticed that my original wire harness has 2 plug ins next to the fuse box. All the other wire harnesses that have fog light hook ups don't have the 2 extra plugins on them. What other montes with fog lights have the 2 other plug ins on the wire harness.
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
nitehwk10
May 8, 2008 06:44 PM
nitehwk10
May 7, 2008 10:40 PM
dogmanx
Jan 13, 2007 10:49 AM
