Fog Light Brackets 6th Gen
35watts is the output from the hid ballast.
I have three of these mounted in a row in the console where the heated seat buttons would be. That section of console pops right out for easy drilling and wiring. They're a nice low profile switch and blend in quite nicely.
http://www.microcepro.com/images/ni112a_web.jpg
is the relay kit the thing that is sold seperately with its own switch and all? i just wanted to drill a hole and wire it myself and call it a day, would a standard toggle switch work just for the hids? how many amps should i look for in a switch if im just wiring straight to the hids?
The relay kit is sold separate and is only the relay and harness that plugs into the ignitors. As far as the switch goes, with the relay kit installed the HID's pull very little. I don't know the amperage of my switch, but would guess 20A would be fine. Ideally you don't want to run without the relay kit, as using the relay assures you have maximum power at the lights with minimal draw on the system.
02monte3.4LS
07-28-2010 10:31 AM
superrod29
09-17-2009 04:53 PM
superrod29
09-14-2009 04:09 PM
