6th Gen ('00-'05): Door Handle popped off.
Whether or not you need a new door or not depends on the cost of repairing the damage done versus the cost of a (hopefully in same color) used door from the wrecking yard.
As far as the lever not staying on the lock cylinder, you may be missing the retainer. It is #21 in the attached diagram. If you're lucky it might be laying in the bottom of the door. If not it's only a couple of bucks through the parts department at the dealer.
Also check and make sure the rod is connected the correct way. I had mine apart and had one part put back in from the opposite direction. needless to say it didn't work.
David here is a good site for diagrams and part numbers. 2004 Chevrolet Monte Carlo SS Parts
Thanks!
1ATony
FWD Tech Guides '95-'07
Feb 1, 2011 01:23 PM
