View Poll Results: Which Hood?
#1 C5 Ramair design
80.00%
#2 durflx
20.00%
#3 AA ss hood
0%
Voters: 5. You may not vote on this poll
Custom Hood Opinions
Old Jul 3, 2012 | 07:31 PM
MeanShwaMonte's Avatar
Default Custom Hood Opinions
Hey guys I'm a member of the current 10 person custom hood group thread started but my inclusion is really based on the final design choice by the majority, if I am not a final involved member this off season I will be creating my own one of a kind custom hood which has always been my true interest, just picked up my project hood from the scrapyard says was off a 04 black SS and will be placing one of the possible hood scoops onto our steel base hood, I plan on doing a full bolt down no epoxy not risking cracks just going to bodyfill it smooth after and will be filling the stock hood lines that run front to back, also will be cutting making it a semi functional hood at least in terms of just getting air into the engine bay cooling only. I know cpl will say I would be better off going with the MPD hood as its allrdy all done functional and is pretty simlr to a couple of these to some people its again just a personal project want to do
Thanks guys hope to hear your opinions! Jeff
Here are the choices
Old Jul 4, 2012 | 06:37 AM
I chose #1 but i guess I am a fan cause it looks sort of like mine.
Your right I think you'd be better off with a MPD hood, becuse it is functional ram air.
Old Jul 4, 2012 | 08:20 AM
03SSLE's Avatar
I like the look of #1, but I think a scoop similar to that without the horns sitting closer to the front would look even better. If you're going to fabricate your own you may want to consider a metal scoop welded on instead of a bolt on option. With the bolt on you will have parting lines between the hood and scoop unless you mold it with epoxy/fiberglass. But then you run the risk of cracking...something you said you want to avoid. With a metal scoop welded on it becomes an integral part of the hood and there's no chance of cracking. Just a thought...
GaMe oVeR
Oct 2, 2012 12:17 AM
Mr Grizzly Mint
Jul 4, 2012 08:50 PM
turbo monte
Jun 25, 2012 10:02 AM
MeanShwaMonte
Jun 22, 2012 09:11 PM
nugmtg757
Jul 1, 2011 06:38 PM
