air splitter/dam
Old May 31, 2011 | 09:15 PM
Monte SSV's Avatar
Default air splitter/dam
Has anyone installed an air splitter or dam on their car that can direct me to a quality manufacturer or distributor? I prefer a referral instead of the hit or miss google search. This is suppose to provide additional cooling with increased air flow. Thanks
Old May 31, 2011 | 09:28 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Sorry man. No luck. If you search "Wind Splitter" more results pop up though. Good luck!
Old Jun 1, 2011 | 06:32 AM
Monte SSV's Avatar
Appreciate that - thanks
Old Jun 1, 2011 | 10:07 AM
Different than the one that is stock?
Old Jun 1, 2011 | 07:31 PM
Monte SSV's Avatar
Not so much as different but in addition. I did check wind splitters and found more options not necessarily what I was looking for. I just want to add a small 1" piece that is angled down about 45 Degrees from the existing stock bumper - wrap around the whole front and simply redirect the air flow up and into the grille and radiator. It would screw right onto the existing bumper at it's most outer edge and look stock like it came from the factory. Something functional and OEM looking.
Old Jun 1, 2011 | 07:34 PM
Monte SSV's Avatar
Chibiblacksheep: The picture of your black Monte almost looks like it has what I am looking for. My '07 does not have that front wrap around skirt on the front bumper as is pictured on your car. Is that an add-on? But pretty much is exactly what I want.
Old Jun 2, 2011 | 11:22 AM
The silver piece? That's the stock bumper, I just painted the bottom silver.
If you put something on the bumper that hangs lower, it will work against the plastic piece behind the bumper that directs the air flow and your car could be hotter.
Mar 8, 2011 03:12 PM
augi
Oct 6, 2010 04:00 PM
thomasnchy
Jun 3, 2008 10:09 PM
WhipItGood
Mar 16, 2008 07:47 PM
