AHH so PiZZed
Old Jun 7, 2012 | 12:44 PM
MonteSSS's Avatar
Default AHH so PiZZed
So I kept reconditioning my sun roof since it was all nasty and got it looking real good. BUT than when i went to open it it started sticking since the rubber had expanded so much and i literally had to push the window up and out. it seems as if the motor is still good because it alwaysworks and what not but it wont close flush or open without a issue the rubber just keeps getting in the way so im guessing i just should get a new seal so it will fit better ? any inputs?? help me!!!!!
Last edited by Space; Jun 8, 2012 at 05:18 AM. Reason: add Z's to our family forum : )
Old Jun 7, 2012 | 11:50 PM
Maybe you could lube it up a bit with some silicone lube or a light grease.
Old Jun 7, 2012 | 11:55 PM
Mr Grizzly Mint's Avatar
Use Graphite, silicon might cause debris to stick to glass. I would put in a new seal better safe then sorry lol.
Old Jun 8, 2012 | 11:40 AM
Id be curious what you consider reconditioning on your sunroof...
Does this mean you used some off the shelf product on the rubber seals?
Did you R and R the sunroof?... or just "clean" and lube it.
If you happen to have used some off the shelf product, it may have contained some form of petroleum disolate...which caused the rubber seals to swell up...
Which leaves you no choice but to replace all the rubber seals....
Old Jun 8, 2012 | 11:49 AM
MonteSSS's Avatar
used white lithium grease and it seemed to soak it right up real good, but i think too good after all. good or bad?? i am going to replace the seal just to be safe yes and hopefully it will fit better
Old Jun 8, 2012 | 12:26 PM
Mr.Monte's Avatar
i used Vaseline and it worked amazingly!
Old Jun 8, 2012 | 12:37 PM
MonteSSS's Avatar
thats what ive been starting to hear^^ thank you!
Old Jun 8, 2012 | 01:47 PM
U do realize that Vaseline has petrolleum dissolates in it also....In my opinion it will also be a dirt magnet like grease is....o, over a long period of time you may have the same problem ariseing again...
Just a Little FYI.
Old Jun 8, 2012 | 04:55 PM
MonteSSS's Avatar
what is your best idea to refurb or condition the seals??
Old Jun 8, 2012 | 05:22 PM
03SSLE's Avatar
That's odd...I don't think it was the white lithium grease that caused the seal to swell. I've been using it on rubber seals and weatherstripping for years and have never had a problem like that. It is also what GM recommends using. Did you use some type of cleaner on the rubber prior to treating it with the grease?
