Aftermarket headlights.
Old Jan 14, 2010 | 07:49 PM
East's Avatar
Default Aftermarket headlights.
Has anyone here purchased aftermarket headlights for 2000-05 monte carlos? If so how'd they turn out and were they any good? I've been thinking about replacing mine with some of those black ones on ebay or smoke ones which I can't find at the moment, and maybe upgrading to HID but I need to know more about the difficulty of installing kits before I dump my plans for silverstars. I've heard about people frying their car wiring with HIDs so that's kind of a worry that I have about that.
Any help is appreciated, keep in mind that I have little working knowledge involving electrical matters but am movitated to learn.
Old Jan 14, 2010 | 08:14 PM
CMC's Avatar
CMC
I have a set of the black headlights with amber corners (I'm probably the only guy that prefers the amber corner over the clear). They "bolt" right in and fit properly. Everyone that has gotten them has had the same complaint, gray glue visible at the bottom on the inside of the lens where the headlight was assembled. It's not much and barely visible from a distance, yet still, it shouldn't be there. Also, on the set I have the rubber that acts as a gasket/buffer between the headlight and body was not glued on very well, both glue adhesion and position. This was easily solved by pulling the rubber off and gluing it back on (positioned right this time) with some 3M black weatherstrip adhesive.
Old Jan 15, 2010 | 08:16 AM
CMC did you purchase them from ebay, or from a place like PFYC??
Old Jan 15, 2010 | 01:04 PM
CMC's Avatar
CMC
ebay. From what I remember, the black headlights, regardless of seller, are the same headlights. So don't spend the extra $100 at PFYC.
Old Jan 15, 2010 | 01:17 PM
Was just curious if there was a knock-off on ebay that was cheaper quality that forced all those fixes.
Was planning on buying mine through E-bay, like I did with my LED tails to avoid the mark-up.
Old Jan 15, 2010 | 01:22 PM
CMC's Avatar
CMC
Heh, funny you should say something about knock-offs. Reminds me of when PFYC started to sell the knock off of MPD's ramair Monte hood.
Old Jan 15, 2010 | 01:57 PM
East's Avatar
So, wait, there's two brands that make the same headlights. Which is better and who makes the original? I definitely would rather spend the extra money for a better pair. I mean, if I'm going to do it, I might as well do it right. Thanks guys.
Old Jan 15, 2010 | 05:43 PM
CMC's Avatar
CMC
No, there's multiple sellers/retailers for the same headlights. The only difference as far as the black headlights go is the clear or amber corner lens. Which when I checked ebay earlier today to see the prices of the black headlights I didn't see the clear corner version. So the clear corner version/option may no longer be available.
As for who makes the black headlights, I"m not sure, but I do believe I remember someone saying they were made in Taiwan.
Old Jan 15, 2010 | 06:27 PM
yeah there all the same & the clear is no longer avail b/c its not DOT legal
jbmul1988
Feb 28, 2011 01:55 AM
96_Monte_carlo_LS
Dec 8, 2009 03:20 AM
Gnapp
Jun 15, 2007 03:18 PM
mikeyB976
Jan 27, 2006 05:39 PM
