5th gen aftermarket headlights
Old Feb 25, 2011 | 12:21 PM
jbmul1988's Avatar
Default 5th gen aftermarket headlights
lookin for a set of aftermarket headlights for the z34. anyone got any ideas? heard some of them are not that bright. possibly use hid conversion? or use the expensive silverstars?
Old Feb 25, 2011 | 01:25 PM
7801MonteMan's Avatar
http://mymonte.com/discussion/topic/...ar-headlights/
Apparently these are hard to come by for the 5th gen MC.
Old Feb 25, 2011 | 03:45 PM
Cully77's Avatar
Monte Of The Month -- May 2011
They're all the same, so light output will be the same in all. I did a mod to mine that helped slightly if you're interested. Lot's of threads on these lights over at mymonte
Old Feb 25, 2011 | 04:10 PM
I've got the black ones on mine- light output sucks as mentioned above. They look great, but you can't see. IMO just shoving HID bulbs in them wouldn't be that great either- its the design of the reflectors that makes all the light output focus into two narrow strips on the road, instead of being nice and spread out like stock. Sticking a higher output bulb in there is just going to give you brighter narrow strips of light.
The best solution IMO for them is to retrofit some projectors in there. That way you would have the great light output of HIDs & projectors with the nice look of the aftermarket headlights.
Old Feb 26, 2011 | 09:06 AM
jbmul1988's Avatar
ok thanks. monte man that link didnt work but thanks anyways. cully what did u do to ur headlights? nything will help at this point. thanks
Old Feb 26, 2011 | 09:38 AM
jbmul1988's Avatar
will lumina headlights of the same year work?
Old Feb 26, 2011 | 11:41 AM
Cully77's Avatar
The lumina and MC headlights are identical.
I baked mine in the oven to remove the lenses and removed the metal reflector inside the low beams. It spread the light out a little more, but the light output was still pretty poor. Regardless, I ran those lights for 2+ years with no accidents haha... and nobody ever flashed their brights at me or anything.
Old Feb 26, 2011 | 01:56 PM
gothkid's Avatar
The expensive silverstars don't help either, I did this on mine it just made the beams longer. I would look into bumpin's idea, with the projectors.
Old Feb 27, 2011 | 12:29 AM
jbmul1988's Avatar
they have a youtube series on hid projector conversion. it looks complicated. need a lot of different tools and materials. idk if thats something that i should try.
Old Feb 27, 2011 | 10:15 AM
nitehawkjcb's Avatar
If you do a lot of night driving, don't get them, trust me
