where to buy factory paint
Old 10-02-2011, 10:33 PM
mstrmysterious63's Avatar
Default where to buy factory paint
anybody know a good site for buying factory paint? preferably in spray paint form.
Old 10-02-2011, 11:29 PM
Is your color a tricoat paint i cant rmbr if it is but if so spray paint will not exist for it, what are you wanting painted?
Old 10-03-2011, 01:40 AM
Your local auto paint supplier can mix any color for you and put it into a spray can. It will be a bit expensive. Depending on the paint type you may need two or three different cans if you have multi stage paint. The spray cans work best with lacquer or enamel.
You should find a listing in the yellow pages. If not check your local auto parts store or body shop. Some of them also mix paint.
Old 10-03-2011, 07:25 AM
The oem paint is PPG
Old 10-03-2011, 12:44 PM
What is it that you want to paint?
Old 10-04-2011, 02:09 AM
i kow it exists in spray form. i saw it a while back but cant remember where. its not a tri coat.
im painting interior plastic trim.
Old 10-04-2011, 11:14 AM
I am almost certain that Eastwood carries interior paint. On those plastic pieces make sure that you wash them with soap and water. I usually use dish detergent. Dry them really good. Let them sit in the sun to warm. Spray them with a good plastic primer so that the paint won't peel. Now they are ready for paint. I hope this helps.
Old 10-04-2011, 11:43 AM
xxtheshockerxx's Avatar
RED DEVIL
you paint will be difficult to match perfectly. some part stores can mix it into a spray can
Old 10-04-2011, 10:34 PM
it doesnt have to match perfectly, since its not going to be side by side with the exterior paint.
i found these sites
<CITE>Touch Up Paint from PaintScratch.com</CITE>
<CITE>http://automotivetouchup.com/</CITE>
<CITE></CITE>
<CITE>but im screptic when it comes to ordering from random sites. </CITE>
Old 10-04-2011, 11:17 PM
RED DEVIL
i would ask around at parts stores...ones that deal with paint products there are a couple around here that will mix you factory paint in a can. I almost bought some the other day for my engine cover but decided it would be better to do it by air brush
Quick Reply: where to buy factory paint
