>Top 10 fuel-efficiency myths ? + gas saving tips <
Old Sep 15, 2013 | 09:10 AM
Question >Top 10 fuel-efficiency myths ? + gas saving tips <
Top 10 fuel-efficiency mythsMember's, post your comments/thoughts on this subject ? Do you agree or disagree ?
<cite>By Doug Newcomb of MSN Autos</cite>
No matter what the current price of gasoline, savvy drivers are always looking for ways to get the most miles from each gallon. But many fuel-efficiency tricks that may have worked years ago for vehicles equipped with less sophisticated components simply don't apply in today's world of computer-controlled automotive systems. And some, upon closer inspection, never did make sense. Take a look at the top 10 fuel-efficiency myths to discern fact from fiction.
  • 1 of 12
Old Sep 15, 2013 | 11:46 AM
Debunking fuel-economy myths
Get a reality check on 7 common fuel-saving misconceptions
Consumer Reports magazine:
Homepage 300
Like all drivers, you want to save gas and do what’s right for your car. But along with the tried-and-true advice, there are some well-intentioned—if off-the-mark—tips that can lead you astray. Below are several common myths about fuel use and gas mileage, and the real stories behind them. (Learn more about fuel economy and how to save at the pump.)
A dirty air filter drops gas mileage
Our tests show that driving with a dirty air filter no longer has an impact on fuel economy, as it did with older engines. That's because modern engines use computers to precisely control the air/fuel ratio, depending on the amount of air coming in through the filter. Reducing airflow causes the engine to automatically reduce the amount of fuel being used. Fuel economy didn't change in the family sedan we tested, but it accelerated much more slowly with a dirty filter.
Warming up before driving is necessary
That was true back in the days of carburetors and chokes, but it isn’t the case with modern fuel-injected, electronically controlled drivetrains. Engines are most efficient when they’re at regular operating temperature, and the fastest way to reach that point is to drive right after starting the car.
Filling up when the air is cool gets you more gas
A common tip is to buy gasoline in the morning, when the air is cool, rather than in the heat of the day. The theory is that the cooler gasoline will be denser, so you will get more for your money. But most stations store the gasoline underground, so its temperature changes very little, if at all, during a 24-hour stretch. Any extra gas you get will be negligible.
No-name gas stations offer lower-quality fuel
Independent stations usually buy their fuel from larger, name-brand oil companies, so it’s not much different from what you’d get for a higher price down the road. Off-brand gasoline is sometimes formulated without additives designed to clean the engine, but your car should run fine on that gas.
Premium gas is always best
When it comes to regular, midgrade, and premium gasoline, oil corporations have worked overtime to drill the “good, better, best” concept into our collective driver psyche.
Premium gas has a higher octane rating, usually 91 or above, making it more resistant to pre­ignition, a condition in which fuel burns uncontrollably in the engine. Higher-performing engines are the most susceptible to preignition because they tend to run hotter, which is why premium is often recommended or required for sports and luxury vehicles.
Premium also helps maximize power in high-performance engines. With those engines, if you don't use premium, you might not get full power when, say, accelerating or climbing hills. Most drivers will probably never notice the difference.
The vast majority of cars are designed to run fine on regular. And premium won’t improve performance or fuel economy for those cars, but it will cost you about 20 cents more per gallon.
Our advice: The best gas for your car depends on the vehicle you drive. If the owner’s manual or the sticker on the fuel-filler door says that premium gas is recommended or uses similar wording, you can probably use regular. If it says premium is required, play it safe with the right octane.
Driving with windows open hurts fuel economy
Some people advise you not to run the air conditioner because it puts more of a load on the engine, which can decrease fuel economy. But others say that opening the windows at highway speeds can affect gas mileage even more by disrupting the vehicle's aerodynamics. In our tests of a Honda Accord, using air conditioning while driving at 65 mph reduced the vehicle's gas mileage by more than 3 mpg. The effect of opening the windows at 65 mph was not measurable.
Tires with low rolling resistance are always a smart choice
A lot of attention is paid to a tire’s rolling resistance, which is how much energy it takes to roll along. The lower the rolling resistance, the better your fuel economy will be. Maintaining the proper tire pressure will optimize the rolling resistance and real-world performance. Some tires gain low rolling resistance at the expense of wet-braking performance and tread life—a poor trade-off.
It’s better to look first for a tire that provides good all-around performance in important safety areas such as braking, handling, and hydroplaning resistance. Then use rolling resistance as the tiebreaker.
In our testing, we’ve found two all-season passenger-­car tires that deliver very good performance and low rolling resistance: the Continental ProContact EcoPlus+ and the Michelin Energy Saver A/S. (See our tire-buying advice and Ratings.)
Old Sep 15, 2013 | 11:49 AM
Smile Free Vid 2 Save `Fuel
Old Sep 15, 2013 | 05:07 PM
ohara's Avatar
Great post with a lot of information
Old Sep 15, 2013 | 05:29 PM
I call bs on a few of those in the first link, i'd say to some degree shifting to neutral at stop lights helps because you're reducing engine load. A dirty air filter is going to restrict air flow and ruin fuel economy, my 97 had a clogged filter when I got it and it ate gas. The rest are so so
Old Sep 16, 2013 | 03:24 AM
Hi `Keane, don't shoot the messenger Which ones do you think are b.s. ? Let's debate ? LOL...I can't defend some of them (OK, many of the claims in the post), but some did make me think ? I think ? LOL
Thanks for your post & contribution...
* Thanks `Ken
Old Sep 16, 2013 | 05:06 AM
Gas Mileage Tips
Add our "Fuel-Saving Tip of the Week" widget to your web site!
<iframe name="widgetbox_widget_iframe_0" width="252" height="325" id="widgetbox_widget_iframe_0" src="http://www.fueleconomy.gov/feg/widgets/tips.html" border="0" frameborder="0" marginwidth="0" marginheight="0" scrolling="no" vspace="0" hspace="0" allowtransparency="true"></iframe>
Our gas mileage tips can help you reduce the amount of gas you use. If you are already following these tips, you are probably getting the best gas mileage your car can deliver.
We also provide some useful links if you are interested in more information.
MotorWeek video shows how driving style can affect MPG and offers tips on how to improve fuel economy
Provided by Maryland Public Television
Old Oct 18, 2013 | 01:48 PM
dumbrum's Avatar
I have a 2000 Monte Carlo ss 3.8 which is producing 14-15mpgs city and 16mps hwy. Does anyone know, by experience, a product no too expensive that I can purchase to help save some gas? Im dying here, I love my car and dont wanna sell it bc of the mpgs I am getting outta it. I recently spoke to some guy who has the ECU reprogramming device and he said he can add 3-4 mpgs, at most, for $150. Any comments, links and/or suggestions are greatly appreciated.
Old Oct 19, 2013 | 03:26 AM
How many miles on your Monte Carlo ? Have you had your 'cat checked to see 'if it's clogged ? Are your filter cleaned or changed (air/fuel) ?
Check back on your post to see 'if our expert tech member's post some advice. Good Luck
Old Oct 20, 2013 | 11:03 AM
dumbrum's Avatar
180k miles, I've changed the fuel and air filter myself. I haven't had the cat checked though... ima fo that
Ember Love
Nov 13, 2013 08:51 PM
Antdeez
Oct 9, 2012 07:47 AM
Jomao_o
Aug 19, 2009 05:34 PM
GrandPaDave
Apr 23, 2008 11:33 AM
BeachBumMike
Jul 30, 2007 11:53 AM
