Tightening up a throttle cable?
Old Sep 9, 2012 | 06:25 PM
tps221's Avatar
Default Tightening up a throttle cable?
well i think i need a bit more tension in mine because when i hammer it to get a downshift it doesnt like to do it and it takes sometimes 5 secs for the car to decide to downshift sometimes it does it when i ask any tips to tighten the wire correctly and safely or is my transmission just an *******
Old Sep 9, 2012 | 11:56 PM
Check yout TPS! (throttle position sensor)
The spring tends to get weak...(dirty corroted)
Then clean and replace it...and see if that helps...
Or purchase a new TPS...
Maybe someone else will chime in with more ideas?
Old Sep 10, 2012 | 01:10 AM
tps221's Avatar
ill try and clean it im just not sure what to look for to find it
Old Sep 10, 2012 | 07:32 AM
Heres a pic of what the different sensors look like...
Old Sep 10, 2012 | 07:54 PM
tps221's Avatar
go figure it would be near the MAF i thought it would be somewhere else
Old Sep 11, 2012 | 09:05 AM
It's not the throttle cable.
Are you doing this at about 40mph? That's a huge dead spot.
Old Sep 11, 2012 | 09:49 AM
Budsjlm's Avatar
Thats for a 3.8 he has the 3.1 the maf on 3.1 are on the intake tube, locations will be slightly different i'm sure too
Old Sep 11, 2012 | 10:06 AM
That was the only "detailed" and "Labeled" pic I could find...so he has some idea what it looks like...more over location....
Old Sep 11, 2012 | 11:33 AM
I'm thinking, check your trans fluid, make sure you're not low. Low fluid levels can create issues with shifting.
Old Sep 11, 2012 | 03:30 PM
tps221's Avatar
its been checked and fluid in tranny is maybe a year old but it doesnt slip like it used to when hammered either
