View Poll Results: stay hubcap-less
YES
15.79%
NO
16
84.21%
Voters: 19. You may not vote on this poll
steelies yes or no?
Old Jan 21, 2013 | 07:52 PM
SnakebiteSS's Avatar
This trend is popping up everywhere and I don't quite understand it. I saw a fairly new Camry with the hub caps removed today during my lunch break. It just makes the car look messy.
But to each their own, eh? It's your car; if you like it, go with it.
Old Jan 22, 2013 | 05:14 PM
RocknSS04's Avatar
If I could get those for affordable in 17's I'd be all over them! Far as I know they're 16's. Am I right or wrong?
Old Jan 22, 2013 | 06:08 PM
Getting steelies in 17" shouldn't be too much of a problem. You just have to buy the small chrome colored center caps separately. The center caps fit multiple sizes.
Old Jan 22, 2013 | 06:37 PM
Heres my thought on why you should leave the hub caps on for now...
You live in Massachusettes:
Generally get the kind of winter weather we get also in Michigan (for example) Cold, snow salt,humidity is the enemy when it comes to the studs for instance...ever been running down the road get a flat...Then you stop to change it..and the first lug you try snaps clean off? I have experienced that very scenario!... and like you mentioned before that brake dust is always gonna be an issue... Thus more maintenance...As far as appearance...Like you said you are planning on fixing the dent...So Im guessing your doing your level best to make it look its best... Ther fore...I say leave the hubcaps on...
Then maybe when your able..Maybe consider getting some stock aluminum
rims from the boneyard and maybe theyll have some good rubber on them also this killing 2 birds with 1 stone...
The rims on mine are factory stock aluminum wheels...If you like the look of mine since your on a college budget..(Just a thought).
Old Jan 22, 2013 | 10:20 PM
tps221's Avatar
my uncle has a set the rubber is just bad
Old Jan 25, 2013 | 01:15 PM
werewolf-odst's Avatar
I got the same type of dent to get out the side of my car, so annoying! But when you get some wheels, maybe you could find some Mustand stockers. They would look great.
Old Jan 25, 2013 | 01:59 PM
tps221's Avatar
i think i want some that are like gunmetal now if the rims my uncle has are ok ill do a paint job
Submariner
Jul 3, 2008 01:10 PM
mrl390
Dec 6, 2007 08:22 PM
BeachBumMike
Jul 19, 2007 07:15 PM
zipsayain
Mar 15, 2007 02:29 AM
BeachBumMike
Jan 27, 2007 11:45 AM
