saty mount replacement
For keith,
if you decide to do it yourself
get a pice of wood, put on jack ,
Jack up motor to relive tention on motor mounts,
pull off passanger side wheel,
remove splash guard to gain access to lower mount
undo the 2 bolts in centers of mount and pull old mount out,
replace with new mount and bolt it!
Lower mount is done,
Undo the 3 nuts on the motor side of upper motor mount
undo the 2 nuts on mount
pull up and the mount is out
bolt in
TOP mount DONE!
let the motor down and your off
tools needed
just off the top of my head
15mm or 16mm deep if not both,
13mm or 14mm if not both
peice of wood,
floor Jack,
bolt in
TOP mount DONE!
tools needed
peice of wood,
floor Jack,
Budsjlm
FWD Tech Guides '95-'07
Oct 29, 2015 05:01 PM
rrobert05
Jul 5, 2006 12:03 AM
