On The Prowl
i know how to get the door panel off,im talking about the plastic trim on the outside of the door,i don't know if the SS has it but I know my LS does,its just a small trim of plastic the runs down the middle of my door and I don't really like it
Sorry, I misunderstood your question. You must be talking about the exterior side molding, a 1" wide strip that runs the length of the door, then a separate, shorter piece extends into the rear fender. Those are held on with foam adhesive tape. Use a heat gun to soften the adhesive then slowly pry off with a plastic pry tool. Remaining adhesive can be removed with adhesive remover solvent.
I plan to repaint the car anyways..maybe a candy apple red but im not sure yet
whats your opinion on a wire tuck?i know I could hide most of the wires except all the sensors in the intake,throttle bodyand clean up the spark plug wires,i already found a great place to hide my fuse box and the wires that run to it,i plan to power a lot of accessories so im going to go with an optima yellow top battery and run my power wires to my center console
I think I've mentioned it before, but I think it's a bad idea to do at the same time as your swap. To do it right and to do a real clean job, you'll be cutting and rerouting wires. Any time you start screwing with the harness, there is a possibility to goof something up.
I would just swap the engine as it is, get everything running fine, then worry about making it pretty later. I've just seen too many buggy swap cars (not just l67s) because the person made more changes than they needed to and ended up having a horrible time tracking down gremlins later. It can be hard enough debugging a swap anyways, I wouldnt make it any harder on yourself than you have to.
I don't plan on making anything permanent right now,I'm basically making a plan for after the swap,I wouldn't be able to do it now anyways since I don't know how much to shorten or lengthen wires,I do plan on painting the bay first so I don't have the engine in my way doing it later,
I got a little over 3 weeks until I can buy my donor car so I'm still looking around,I don't really want to take my chances at a junkyard so I'm waiting to find the right one,my best option to find the l67 I'd going to be the gtp or regal,that's the only two cars I've seen in good condition with low miles so far
