No Cat.?
Old May 4, 2009 | 09:02 PM
One Dark SS's Avatar
Default No Cat.?
Would i get a engine code if i was to "disable" the cat in a more then likely illegal way (cut it open, gut it, run straight pipe thrue it, weld it back up)..
We dont have emissions test here in Alberta... so why not would be my second questions?
As long as it looks like theres a cat there in the even that a cop MIGHT actually want to get dirty and look under my car...
Old May 5, 2009 | 06:32 AM
RocknSS04's Avatar
There's more than one person around that just runs a straight pipe there instead of the cat. Some later years are different in their O2 sensors, and might be difficult. In your case, I would put in an O2 simulator and not worry about it.
Old May 5, 2009 | 07:51 AM
the only problem you would run into, is the O2 sensor that's behind the cat. Since it will be running richer than with the restrictive cat, it may MAY may throw a code. but you can just take the code out of your PCM or get the O2 simulator like suggested.
Old May 5, 2009 | 11:32 AM
Aright then, so basicly, the car will run perfectly fine, might just have an anoying light on in the dash...
doing that and adding the u-bend delete, would i notice any difference? mpg? performance?
i just have a lil 3.4l
Old May 5, 2009 | 03:02 PM
I'm sure you'll notice a difference, but nothing dramatic.
Old May 5, 2009 | 03:37 PM
The constant warning light would bug the hell out of me. I'd go with the O2 simulator and just be done with it. Also, if you have the stock sound system, you'll have the warning bell annoying you upon start up in addition to the message lit up in the message center.
Old May 5, 2009 | 03:52 PM
Yeah i got stock deck.. im actually replacing that with 04 one (got it for 25$) mine is pretty warn out, looks like s..t... 60$ at the dealer to get ir reprogramed...
How much does a o2 simulator cost?
Old May 5, 2009 | 04:30 PM
2000_BLACK_SS's Avatar
Old May 5, 2009 | 04:54 PM
TY Sir!
kicker
Apr 2, 2011 09:41 AM
J_Bru_Ha_SS
Aug 4, 2006 03:50 PM
monteriderLS
Jul 15, 2006 04:06 AM
BEAVIS
Mar 30, 2005 09:39 PM
85_Monte_SC
Mar 24, 2005 10:20 AM
