>Lotto Dream Machine + more Dreams<
Old Mar 4, 2014 | 06:37 AM
Smile >Lotto Dream Machine + more Dreams<
The 2015 Lamborghini Huracan:
18 Things You Didn’t Know ?
+ 19. You need to win the lotto to buy one > LOL
Company Says Supercar Will be its Best Street Driver Ever (Member's, do you like it ?)
By Scott Evans | March 03, 2014 |from Motor Trend Magazine
See All 42 Photos < Click 2 EnJoy
Lamborghini released quite a bit of information on the all-new Huracan back in December, but the facts were more like bullet points than detailed descriptions. Now, on the eve of the 2014 Geneva Motor Show, Lamborghini invited us to take a deeper look into the Huracan and there’s a lot more to the story.What you know: “Huracan” is Spanish for hurricane and is the name of a fighting bull from 1879.What you didn’t know: How to pronounce it. If you want to sound like a Lamborghini connoisseur, it’s pronounced ooo-rah-khan.What you know: Its new V-10 makes 601 hp at 8250 rpm and 413 lb-ft at 6500 rpm.What you didn’t know: The new engine is both port- and direct-injected to optimize fuel delivery at every single firing. It also has variable cam timing on all four cams. This comes with a wealthof benefits. The peak power and torque increases nearly 50 hp and 15 lb-ft are just one. Seventy-five percent of that torque (310 lb-ft) is available from 1000 rpm, an impressive achievement for a naturally aspirated engine. Not only does it make more power than the Gallardo and do it from the bottom of the rev range up, but a peek at the dyno chart shows that Huracan keeps making power all the way to redline, where the car's predecessor used to fall off. The new engine even revs faster than the old one, if you really can’t wait to get to that power peak. You’ll enjoy the trip to redline no matter how you get there, thanks to a variable intake sound generator which will pump more intake noise into the cabin the harder you push it. Complementing that is a dual-mode exhaust system that opens under hard acceleration. For those concerned about how all this assaulting of the redline will affect the planet, Lamborghini has fitted an engine start/stop system and reduced both fuel consumption and CO2 emission by 11 percent compared to the Gallardo. A dry sump oiling system allows the engine to be mounted as low as possible for better weight distribution. Front/rear weight distribution, in case you’re wondering, is 42/58. The engine is produced at Audi’s Gyor, Hungary, engine plant alongside the powerplant that goes in the R8.
What you know: It’s got a seven-speed dual-clutch gearbox.What you didn’t know: It’s called “Lamborghini Doppia Frizione” (Lamborghini Double Clutch) and it’s the new Audi R8 gearbox retuned to Lamborghini spec. When you want to beat on it, a launch control system has been fitted and holding the downshift paddle rather than clicking it will drop you to the lowest available gear. When you’re not at the track, Lamborghini promises it’ll be the nicest driving street car the
company
has built. In fact, the company expects the Huracan to be the most-driven Lamborghini ever for that reason. “Easy on the road, absolutely performing on the racetrack,” as CEO Stephan Winkelmann puts it.What you know: It doesn’t have a manual transmission option.What you didn’t know: It won’t. According to company executives, manual transmissions accounted for an average of two percent of all Lamborghini sales over the last decade. The highest the take-rate ever got was five percent, and that was the same year the company saw the highest Gallardo sales ever. There just isn’t a
business
case for a small company like Lamborghini developing a transmission so few people will buy, especially with all the work it would take to make it work with the new chassis dynamics system on the Huracan. Even if the work got done, Lamborghini says taking control of the transmission away from the computer would blunt the system and thus the performance.
What you know: It’s
all-wheel drive
.What you didn’t know: The old viscous-coupling system is gone. In its place is a fully computer-controlled system that’ll dish the power exactly when and where it’s needed. Nominally, power will be split 30/70 front/rear, but the computer can send up to 50 percent of the power to the front and up to 100 percent to the rear as conditions demand it. Transferring power is actually handled at the front axle, where a wet multi-plate clutch decides how much power to send out to the front tires.What you know: It’s got an optional variable-ratio steering rack.What you didn’t know: It’s electric steering, and it’s designed to alter the ratio with the
performance
. Below 31 mph, the steering will be quicker and more direct to make a sharp corner, which will make it easier to get in your garage. Above 62 mph, the steering will become slower, requiring more steering input for sharper turns in order to increase high-speed stability. The variable-ratio system can also help control oversteer by making “tiny, targeted countersteering impulses.”What you know: It’s got Magnetorheological shocks.What you didn’t know: The adaptive, electronically controlled shocks are icing on suspension cake. The suspension is entirely aluminum and is composed of double A-arms at all four corners. Hanging off the ends are two 20-inch wheel designs, one even lighter than the other. They’re wrapped in Pirelli PZero tires designed specifically for the Huracan, the best blend of street and track performance as well as ride comfort and fuel efficiency.What you know: It’s got carbon-ceramic brakes.What you didn’t know: They’re massive at 15 inches in the front and 14 inches in the rear. They’re clamped by six-piston calipers up front and four-piston calipers out back. The parking brake is electronic. Lamborghini says the brakes will haul the Huracan to a stop from 62 mph in 105 feet, though we have a feeling it’ll do quite a bit better than that. At minimum, that’s 3.6 feet shorter than the quoted stopping distance for a Gallardo, though the last Gallardo we tested – a Valentino Balboni Special Edition – stopped in 104 feet.What you know: It’s got an advanced chassis dynamics system.What you didn’t know: This might be the most technologically advanced car Lamborghini has ever built. On the surface level, you’ll be able to alter the car’s performance via the ANIMA switch on the bottom spoke of the steering wheel. ANIMA stands for “Adaptive Network Intelligent Management,” because Lamborghini really wanted to acronym to spell the Italian word for soul (anima). As you cycle from Strada (street) to Sport and Corsa (race), ANIMA will make changes to the throttle response, transmission response, dampers, stability control, all-wheel drive control, the intake and exhaust noise flaps, and the variable steering if you’ve got it. Informing those changes is Lamborghini’s Piattaforma Inerziale, an aerospace-inspired technology. It utilizes three accelerometers and three gyroscopes placed at the car’s center of gravity to measure acceleration front-to-back, side-to-side, and up-and-down, as well as roll, pitch, and yaw. All of that information will be relayed to the computer as it decides how best to make use of all the variable components on the car.Want more on the 2015 Lamborghini Huracan? Read the rest of this feature RIGHT HERE.
View All
Next Page
Last edited by Space; Mar 4, 2014 at 11:38 AM. Reason: Because I keep messing `up 4-Sure (LOL)
Old Mar 4, 2014 | 11:34 AM
Smile Top 10 (?)
More Lotto Dream Rides > EnJoy
http://www.autobytel.com/top-10-cars...FTBk7AodXXgAZw
Top 10 Sports Cars
#102014 Mercedes-Benz SLS AMG
The standard features of the Mercedes-Benz SLS AMG GT include AMG 6.2L V-8 583hp engine, 7-speed auto-shift manual transmission with overdrive, 4-wheel anti-lock brakes (ABS), integrated navigation system, side seat mounted airbags, curtain 1st row overhead airbag, driver and passenger knee airbag, airbag occupancy sensor, automatic air conditioning, 19" AMG forged aluminum wheels, cruise control, and an ABS and driveline traction control.
Smile For us working people (LOL) EnJoy
Top 10 Coupes and Compact Cars
http://www.autobytel.com/top-10-cars/new-cars/coupes/
#102014 Subaru BRZ
The standard features of the Subaru BRZ Premium include 2.0L H-4 200hp engine, 6-speed manual transmission with overdrive, 4-wheel anti-lock brakes (ABS), integrated navigation system, side seat mounted airbags, curtain 1st and 2nd row overhead airbags, airbag occupancy sensor, air conditioning, 17" aluminum wheels, cruise control, and an ABS and driveline traction control.
Old Mar 4, 2014 | 01:27 PM
Smile For `Devin & Lotto Winner's
2015 Aston Martin V12 Vantage S
By Laura Burstein
On Sale: Early 2014
Expected Pricing: Starting at $184,995
Aston Martin's fastest Vantage was unveiled in Monterey, California, during the week of the Pebble Beach Concours d'Elegance.
The 2015 Aston Martin V12 Vantage S is outfitted with a revised 6.0-liter AM28 V12 engine that makes 565 horsepower and 475 pound-feet of torque (versus 515 hp and 438 lb.-ft. on the previous model). Aside from the British marque's limited-production One-77 supercar, the V12 Vantage S is the fastest Aston Martin to date, with the company claiming a 0-60 mph time of 3.7 seconds.
From the outside, changes to the new V12 Vantage are subtle. The body is slightly refreshed, most notably around the front fascia. A black, honeycomb-shaped mesh grille insert replaces the chrome horizontal bars found on the outgoing model, swapping elegance for a racier look. Aston reps say the new design was inspired by the CC100 Speedster concept car that debuted at this year's 24 Hours of Nurburgring endurance race. New graphics and wheels also appear on the new V12 Vantage S.
The 2015 Aston Martin V12 Vantage S is fitted with a new gearbox, a 7-speed automated manual that replaces the old 6-speed transmission and weighs 55 pounds less. It's the same one used in the V8 Vantage S, and a close variant of those used on Aston Martin's FIA GT racecars. Gears can be shifted via steering wheel-mounted paddles that are wrapped in leather or carbon fiber. A limited-slip differential is standard.
A new suspension features adaptive damping. The front suspension gets coil springs, antiroll bar and monotube dampers, while the rear uses dual-rate coil springs.
For the first time, the V12 Vantage will offer a choice of three driving modes: Normal, Sport and Track. The settings change the firmness of the suspension and adjust the new ZF-Servtronic power-assisted steering system. Of note, Aston Martin still uses hydraulic steering, unlike many manufacturers that have switched to electric. Many drivers prefer the feel of traditional power-assisted hydraulic steering over the new electric steering systems.
The chassis of the V12 Vantage S is lighter than its predecessor, and aerodynamics and airflow have been tweaked to improve cooling and engine performance, aided in part by redesigned air ducts and a new carbon fiber front grill.
Aston Martin claims a 30 percent reduction in noise, vibration and harshness due to new insulation material that's made from 80 percent recycled materials.
Brakes come with huge, cross-drilled carbon ceramic rotors. Forged alloy wheels come fitted with standard Pirelli P Zero Corsa all-season tires; Pirelli P Zero summer times can be ordered instead for the same price. Pricing for the 2015 Aston Martin V12 Vantage S will start at $184,995. Cars are expected to arrive in dealerships in early 2014.
Old Mar 4, 2014 | 07:57 PM
ohara's Avatar
I like the Lambo, it is a sweet looking ride that would surely thrill you from the second you opened the door.
The first thing my wife said when I showed her the pics was "that thing looks like a monster (referring to the front end) and I kind of agree with her. It has a very aggressive look to it, but you would expect that from a car of that stature. I am just not sure if I could fit inside one of those, but I would definitely try
When I get the money saved up my wife and I are already planning on experiencing this
Dream Racing - Driving experience at Las Vegas Motor Speedway
but....we want to drive every car they have to offer so that you get the true experience of the vehicles
Old Mar 5, 2014 | 08:52 AM
Smile Thanks Ken 4 your post/words/sharing
Hi `Ken, thanks for your post & sharing your dream. Yes, it does look like a monster that would scare any vehicle around it.
I love your dream plan & I also would really love to experience the >Dream Racing experience 4-Sure<
Wish all your dreams come true
Dec 19, 2014 04:53 AM
Jan 13, 2012 12:52 PM
Sep 12, 2010 07:20 AM
fadedfutures
Aug 12, 2009 09:11 AM
Apr 9, 2009 07:47 PM
