Gonna spend repair money on upgrades instead
first euro headlights then a sub box for cheap i did get a 1043 dollar check
Sondpex 400 Watt 8" Speaker Stereo System with Neon Ring | Product Details | Pep Boys this found it cant be bad bad
maybe this amp
Walmart.com: dB Drive A1 500 Amplifier: Auto Electronics
maybe this amp
can you wire up the amp without going to the battery i saw in the manual there should be two extra pigtails near the fuse box
http://www.pepboys.com/product/detai...io/subwoofers/ maybe this instead
This thread is a fail just by what the title says. The number one rule of modding is fix all the problems first then add custom work cuz a modded car wont do u no good when its broken down on ur drive way unable to move
Im guessing that money is from the dent you got in your car? You're going against yourself a bit here, as you were very upset that it happened and now suddenly you dont care?
everyone is claiming its gonna cost the check or more and it's aggravating. the last guy said something about hooking to the frame to tow it out. and then he said id take the check and just leave it. i have gotten kind of use to it and yeah it bugs me but it has no mechanical isssues from it just cosmetic. me and my dad are gonna try and pop it back from inside then decide anyways my grandmother gave me a 200 dollar check for graduating im can use 99 of it on the subs and not cut into the repair check
Maybe the subs will rattle the dent back out.
But really, if you're cruising around in a dented up 5th gen with subs loud as hell, you will get some pretty funny looks. Just sayin.
