fwd to rwd
fwd to rwd
alright guys i gotta random idea for the future...i have a 383 stroker at home..bad *** motor but no car...so im thinking when i get a place and a garage and money obviously ill sit the monte and work on a long rwd conversion...it would be very difficult but very bad ***...theyre set up to do it tunnel and all but still a project. whatcha think?
i dont know about the tank you may ned to get anouther one and place it in the trunk or behind the drive shaft like the mustang and the 3-4th gan are. that is one of the things are hampering me on doing a conversion like that is is all about the where the tank is going. or where the drive shaft is going you may have to do a custum make a gas tank all in all. with that said it is possible but the gas tank is the problem. but there is a guy here that did a fwd to a rwd monte but i dont know if he still is part of the family
I vaguely remember someone mentioning that there is a converted 6th gen out there somewhere. And it took an ungodly amount of work to do it.
If I remeber correctly, I think the guy used the drive train from a donor car that was already RWD. Then went from there.
You may be better off doing that. You'd still have a lot of work to do modifying the body.
i have it is possible on the 6th and 7th but the problem i have seen is the gas tank the drive shaft will need to go threw it. the mercury cougar that my dad has the drive shaft goes threw the gas tank. what i mean is the tank is shaped for the drive shaft to go threw it as in the tank has a u shap in it for the shaft to pass threw so it wont tuch the tank plus a u hold for the drive shaft if the u joint breaks the u hold catches it. but there will be aa need for three two on the botum one on top. then it will be fine no drive shaft hitting the gas tank that is what i have looked into. also i do have at least three canidates of engines to go in but i need a daily driver not anouther hot rod not yet ;P
its been done before the one thats on this forum used c5 vette drive train. and if the fuel tank is an issue run a fuel cell. i think that would be the least of concerns if you had the fabrication skills to do the conversion. the 6th gen video got removed. it caused a commotion with some ppl about the way the car was driven on a open road.
heres the 5th gen one. i believe on the 5th gens they use gbody frame and place the 5th gen body on it.
http://www.youtube.com/watch?v=XJKsDAhKusM
http://www.youtube.com/watch?v=1xXgitwtB54
