filled up with 89 to test the difference.
Old Sep 14, 2013 | 02:59 PM
  #31
JC Colon's Avatar
Oh OK! We called it Retarding or Advancing the Timing back in the days of Distributors. Since the timing is controlled by the computer now a days that makes sense. Thanks for the Clarification Keane!
Old Sep 14, 2013 | 03:08 PM
  #32
owens91's Avatar
well personally i seen no difference, i normally use 87 and i used 93 just to see the difference, but with the use of my app the tracks all data of the car there was really no differencee but dont hurt to try to see results
Old Sep 14, 2013 | 11:26 PM
  #33
Griffindor's Avatar
Well these guys are talking about running 89 or 93. I'm talking about running ethanol free gas and seeing how that does.
Old Sep 16, 2013 | 08:06 AM
  #34
If you can find ethanol free gas, then go for it!
Your car was made back when ethanol wasn't a thing in fuel.
Old Sep 21, 2013 | 06:57 PM
  #35
tps221's Avatar
so 89 made the low end torque much stronger but it made the engine run warmer than normal so probably not safe to run it. I put in a spectre knock off K&N style filter ($20) so far so good even get the CAI sucking noise
Old Sep 27, 2013 | 12:43 AM
  #36
djhixter's Avatar
it doesn't really matter the octane you are running. most cars anymore operate perfectly fine on 87. that's what the computer is designed to run on. if your car is detonating on 87 octane, there is a problem somewhere. using 93 octane is a big waster of money and won't really make the car run any better and/or worse. as for transmission shifting, if the engine isn't running correctly, neither is the transmission in most cases. the transmission will shift when the pcm tells it to, depending on engine load, timing etc
jimmy2blazer
Apr 7, 2024 02:58 PM
turner_dtp
Jan 1, 2007 08:48 PM
BeachBumMike
Nov 30, 2006 08:37 PM
04MonteLS
Jul 1, 2005 03:00 PM
04MonteLS
May 30, 2005 05:34 PM
