View Poll Results: Do you like it ?
Yes, I'd like to have one
66.67%
No, it's not 4 me
33.33%
I'll post what I'd buy instead for the $'s
0%
Voters: 3. You may not vote on this poll
>2016 Chevrolet Silverado 1500 - First Drive Review <
Old Oct 4, 2015 | 10:55 AM
Arrow >2016 Chevrolet Silverado 1500 - First Drive Review <
<LI id=breadcrumb-model abp="424">/ <LI id=breadcrumb-title abp="428">2016 Chevrolet Silverado 1500 - First Drive Review
A mild pick-me-up for Chevy's honest pick-'em-up.
    That is the final line in our entry for the 2015 Chevrolet Silverado in a recent four-truck comparison test, a test in which the Chevy finished second behind only Ford’s newer F-150. As we’ve been saying since the truck debuted for 2014, the squared-off, steel-bodied, leaf-sprung Silverado, on paper, is completely unremarkable. And yet somehow, the assemblage of its entirely unexotic components is something more. For 2016, the Silverado retains its simple hardware but gets a new face, expands the availability of its optional eight-speed automatic transmission, and adds Apple CarPlay integration.
    If that list of updates sounds comprehensive, it really isn’t. Besides a newly topographical hood—with more creases stamped into it than seemingly every other body panel combined—and the loss of its stacked headlights, the 2016 looks the same as the 2015. Inside, there’s nary a hint of disturbance, with the dashboard, steering wheel, and seats carrying over unchanged. As we mentioned, there is Apple CarPlay (Android Auto integration joins the party in a few months), and it’s operated via the uplevel 7.0- and 8.0-inch MyLink touch screens. The look of the screens is familiar, although they now share internal hardware with the upgraded units in the 2016 Malibu, which means they respond more quickly to inputs than before.
    Advertisement - Continue reading below
    One Big Change
    Really, the only notable mechanical change is the migration of the 8L90 eight-speed automatic transmission from the 6.2-liter V-8 engine to certain Silverado trim levels with the 5.3-liter V-8. So far, only the LTZ and the High Country models with the smaller engine get the eight-speed—everything else, including the base V-6, uses the old six-speed unit. Although we’re okay with the 2016 refresh’s overall cautiousness, this is one area where Chevrolet needed to go further. The old six-speed is slow to downshift (once its electronics register a kickdown at cruising speed, it momentarily engages fourth before pausing and belatedly grabbing third), and with fewer gears it holds onto lower ones longer even under light throttle applications. The eight-speed’s wider ratio spread and quicker shifts allow for spirited acceleration using lower engine speeds, surely a boon to real-world fuel economy; kickdown requests are met with a lower gear and far less hesitation.
    Chevrolet says the only other mechanical changes address IIHS’s new narrow-offset frontal crash test. There is more structural sheetmetal tied to the base of the A-pillars and integrated into the front of the rocker panels to limit footwell intrusion during the tough narrow-offset test. The additional material adds some stiffness to the structure, which spurred the engineers to retune the truck’s dampers. An engineer told us, however, that an identical suspension feel was targeted; as he put it: “You’re not supposed to notice” the changes. That’s all well and good, because the Silverado already boasts the best ride-and-handling balance in the full-size-truck realm, with well-controlled body motions, a firm but not punishing ride, and relatively sharp steering. And can other truck manufacturers please benchmark the Chevy’s brake-pedal feel? Firm and responsive, it’s a far cry from the mushy and overboosted units in other pickups.
    Fresh Face
    We like the Silverado’s new face, too, even if it’s only window dressing on an otherwise unchanged rig. The thin, projector-beam headlights are standard on every model, and upper trim levels wear LED jewelry. With the stacked headlights gone, the front end appears lower and wider; it’s handsome, even if cleaning every nook on the undulating hood will require a step stool and the wingspan of an NBA forward.
    Once again, Silverado buyers face a nearly limitless set of body and drive configurations, but the basic trim-level structure remains. There are the Work Truck, LS, LT, LTZ, and High Country versions, as well as regular-cab, double-cab, and crew-cab bodies and myriad bed choices; two-wheel drive is standard, four-wheel drive is optional. In order to get Apple CarPlay, Android Auto, and Chevy’s onboard OnStar 4G LTE data connection and Wi-Fi hot spot, buyers need only shell out $27,850 for a base Work Truck, plus an additional $435 for the optional 7.0-inch MyLink touch screen.
    That sort of technology democratization with the eight-speed transmission would give Chevrolet at least one hardware talking point to throw up against Ram’s air suspension and across-the-board eight-speed transmission and Ford’s aluminum bodywork and turbocharged EcoBoost engines. It also would give the base 285-hp 4.3-liter V-6, a competent and powerful engine choice apparently being ignored by customers drunk on cheap gas, a better chance of breaking through. Even so, as it sits, the Silverado remains a truck-guy’s truck, with an upright dashboard boasting a full array of analog gauges monitoring all manner of engine parameters—and an elegant simplicity not present in the more forward-looking Ram 1500 and Ford F-150. The Silverado is an honest tool, simple and effective. Need a full-size pickup be anything more?
    View Photos View Photos
    Old Oct 4, 2015 | 10:56 AM
    Specifications >
    VEHICLE TYPE: front-engine, rear- or rear-/4-wheel-drive, 2-6-passenger, 2-4-door truck
    BASE PRICE: Work Truck, $27,850; LS, $29,875; LT, $33,870; LTZ, $42,145; High Country, $50,260
    ENGINE TYPES: pushrod 12-valve 4.3-liter V-6, 285 hp, 305 lb-ft; pushrod 16-valve 5.3-liter V-8, 355 hp, 383 lb-ft; pushrod 16-valve 6.2-liter V-8, 420 hp, 460 lb-ft
    TRANSMISSIONS: 6-speed automatic with manual shifting mode, 8-speed automatic with manual shifting mode
    DIMENSIONS:
    Wheelbase: 119.0-153.0 in
    Length: 205.6-239.6 in
    Width: 80.0 in Height: 73.5-74.2 in
    Curb weight (C/D est): 4550-5700 lb
    PERFORMANCE (C/D EST):
    Zero to 60 mph: 5.9-7.6 sec
    Standing Ľ-mile: 14.4-15.9 sec
    Top speed: 110 mph
    FUEL ECONOMY (C/D EST):
    EPA city/highway: 15-18/21-24 mpg
    Old Oct 4, 2015 | 11:00 AM
    Talking >>>raptor<<<>>700 hp
    <LI class="yad-item C Fs Ff Fw Fz Td Bgc "><LI class="yad-item C Fs Ff Fw Fz Td Bgc "><LI class="yad-item C Fs Ff Fw Fz Td Bgc ">Oh Good, Now the Shelby Ford Raptor Makes 700+ Horsepower
    <LI class="yad-item C Fs Ff Fw Fz Td Bgc "> Click above > Your Choice
    Old Oct 4, 2015 | 11:11 AM
    Thumbs up 2015 Silverado below
    My Surfer friend that I met up with yesterday has one like above 2015.
    It's sure a sweet `ride.
    Old Oct 5, 2015 | 12:05 AM
    I'll take a Shelby Raptor 4 sure! But I'm hating the "......" of the led running lights on the new Silverado - just like they have on the Sierra. Not a bad looking truck otherwise, but it's a deal breaker for me. I'll never own one
