View Poll Results: 2014 Corvette ?
I like it
18
90.00%
I don't
10.00%
Voters: 20. You may not vote on this poll
The 2014 Corvette (Released)
Old Jan 16, 2013 | 05:11 AM
  #31
Thumbs up
Official Photos and Info from Car & Driver JANUARY 2013
<HGROUP>2014 Chevrolet Corvette Stingray / Z51
The seventh generation of the American icon has finally arrived.
</HGROUP></HEADER>
  • January 2013
BY ANDREW WENDLER
MULTIPLE PHOTOGRAPHERS
“Iconic.” It’s possibly the word most overused in the last decade. Randomly applied to everything from ’70s television has-beens to retail establishments, and from shoes to athletes, it’s been rendered practically meaningless. But in the case of the Corvette, the word still carries the weight of a blacksmith’s anvil.
Love it or hate it, for more than 50 years, the Vette has unapologetically stood as a universal symbol for homegrown American performance. So when Chevrolet announces it has a new one in the pipe, people get weird. Rumors of mid-mounted engines, piles of carbon fiber, and turbocharging swirl. But now that the drapes have finally sloughed off the 2014 C7 Corvette Stingray—yes, the famed name returns on the base car—we have only truth.
<TABLE class=default border=0 cellSpacing=0 cellPadding=2 width=429><TBODY><TR><TD vAlign=top>
</TD></TR></TBODY></TABLE>
Looks Aren’t Everything, But They’re Very Important
As we surmised weeks ago, the 2014 C7 Corvette takes more of an evolutionary philosophy—although it shares just two parts with the outgoing car—while also sprinkling in some revolutionary details. The C7’s body casts much the same shadow as did the C6’s, but the new car is peppered with more-pronounced creases, larger and more numerous vents, and an angrier front fascia and headlamp treatment. In the front three-quarter view, the tiny hint of Maranello we previously noticed in the C7’s nose is clearly evident. Both the hood and roof are constructed of carbon fiber. The profile is visceral; a stretching, sinewy form emphasized by the subdued B-pillar and a rakish backlight. There's also a rear quarter window. But the stylistic element likely to draw the most commentary is the treatment of the taillamps; although the quad-lens presentation follows Corvette tradition, the new lights' rhomboid shape and the dogleg cutout in which they reside are certain to be polarizing. For their part, Chevrolet says they wanted them “not only to say ‘Corvette, but new Corvette.’ ” A quartet of trumpet-like exhaust pipes exit from the center of the rear fascia, one of the few details made clear in the numerous spy photos we published over the last year.
The Dirty Bits
A naturally aspirated Gen V small-block 6.2-liter pushrod V-8 sits under the hood; it spins a rear-mounted transaxle via an aluminum torque tube. Dubbed the LT1, GM estimates the engine will make 450 horsepower and 450 lb-ft in base form, making it the most powerful standard Corvette to date and our (and GM's) early estimate has 0–60 times clocking in at less than four seconds. Cylinder deactivation is standard, even with the manual transmission, and Chevy says the C7 will best the C6's 26-mpg EPA highway estimate. Two active exhaust systems are available; the base setup uses its active valves to tame noise during four-cylinder cruising. An optional dual-mode system has extra valves that open a less-restricted path for airflow to both increase performance and sound bad-***.
<IFRAME height=315 src="http://www.youtube.com/embed/FrwBHi_bW2M" frameBorder=0 width=429 allowfullscreen=""></IFRAME>
Transmission options are a six-speed automatic or seven-speed Tremec manual—yes, a seven-speed unit, with four shift gates. The manual transmission also features active rev-matching on both down- and upshifts courtesy of patented GM technology. We’re told that it’s fully defeatable for when you’re in the mood to blip yourself. A Z51 performance package will bring an electronically controlled limited-slip diff; closer gear ratios for the manual gearbox; dry-sump lubrication to prevent oil starvation in racetrack settings; additional cooling for the brakes, differential, and gearbox; larger brakes; and aerodynamic bits to increase high-speed stability. Z51s also get 19-by-8.5-inch front and 20-by-10-inch rear wheels and tires, up from the standard 18-by-8.5- and 19-by-10-inch package. Michelin Pilot Super Sport run-flats were developed specifically for the C7. Continued...
<TABLE class=default border=0 cellSpacing=0 cellPadding=2 width=429><TBODY><TR><TD vAlign=top></TD></TR></TBODY></TABLE>
<NAV class=mod>2
PHOTOS (80)
The more I see it & read about the new Corvette, the more I like `it...It's on my Dream List (Now, I just need to win the Lotto)
^ ^The `End of this post, the begining of a new `Dream ^ ^
Cowboy6622
Dec 28, 2011 11:18 PM
Dec 9, 2011 10:54 AM
myfirstbowtie
Jul 19, 2011 10:27 AM
LnLSS06
Oct 15, 2008 02:18 PM
big_mecho13
Jul 25, 2008 09:42 PM
