2011 Lingenfelter Cadillac CTS-V Coupe 0-60 in 3.9 : )
Old Jun 11, 2011 | 05:30 AM
Thumbs up 2011 Lingenfelter Cadillac CTS-V Coupe 0-60 in 3.9 : )
Caddy Coupe Now, maybe a Monte Carlo Coupe in our Future ?
2011 Lingenfelter Cadillac CTS-V Coupe - Specialty File
Lingenfelter’s 700-hp Cadillac CTS-V is a study in physics and “Holy crap!”
For this kind of $ Money $ 4- Real - Sure
BY JARED GALL, PHOTOGRAPHY BY PATRICK M. HOEY
June 2011
Pages: 1 Photos
Yea, 6 speed Stick in a Caddy Jump in & take it
for a ride & see how long it will take you to burn `off
a set of Rear Tires
<!-- /buyers-guide -->Downloads
<!-- /Downloads -->Specifications
VEHICLE TYPE: front-engine, rear-wheel-drive, 4-passenger, 2-door coupe
PRICE AS TESTED: $80,915 (base price: $76,005)
ENGINE TYPE: supercharged and intercooled pushrod 16-valve V-8, aluminum block and heads, port fuel injection
Displacement: 376 cu in, 6162 cc
Power (SAE net): 700 hp @ 6500 rpm
Torque (SAE net): 690 lb-ft @ 4000 rpm
TRANSMISSION: 6-speed manual
DIMENSIONS:
Wheelbase: 113.4 in Length: 188.5 in
Width: 74.1 in Height: 56.0 in
Curb weight: 4212 lb
C/D TEST RESULTS:
Zero to 60 mph: 3.9 sec
Zero to 100 mph: 7.9 sec
Zero to 130 mph: 12.6 sec
Street start, 5–60 mph: 4.2 sec
Standing ¼-mile: 11.8 sec @ 126 mph
Braking, 70–0 mph: 156 ft
Roadholding, 300-ft-dia skidpad: 0.92 g
FUEL ECONOMY:
C/D observed: 12 mpg
TEST NOTES: Lingenfelter recommends getting the tires warm, which means pre-launch burnouts. With so much power and 55-degree temperatures, it’s still a losing battle for grip through first gear. Launch around 2000 rpm—just to avoid bogging—and then use as much gas as you dare. Oh, and don’t forget that this car has a 6800-rpm rev limit.
Like Red Bull–quaffing preteens laying waste to digital innocents by the dozen in Grand Theft Auto, we’re being desensitized. It isn’t graphic violence we’re being hardened against, though; it’s gratuitous horsepower. Outputs that once stopped us in our tracks and slackened our jaws now merit an entitled shrug. Well, good. A Cadillac needs 556 horsepower to, you know, feel like a Cadillac. But 700 is one of those numbers that still widens our eyes and brings a silent “wow” to our lips. Seven hundred horsepower is a reality check.
Reality Checks and Real Checks
For a surprisingly small sum, the laboratories at Lingenfelter Performance Engineering will amplify the 6.2-liter LSA V-8 under the hood of the Cadillac CTS-V from the stock 556 hp to a reality-check 700. Just $11,470 gets you an increase in maximum supercharger boost from 9.0 psi to 14.5, a new camshaft, new fuel injectors, and overhauled heads. Included in the reconstructive surgery are a port and polish, and new valves, springs, and retainers, among other odds and ends. Cadillac is unlikely to honor the warranty on cars that emerge from Lingenfelter’s shop in Decatur, Indiana, which is why the tuner covers the engine and its upgrades with a two-year, 24,000-mile guarantee. (We want to be the guy putting 12,000 miles a year on his 700-hp Caddy.)
<TABLE class=default border=0 cellSpacing=0 cellPadding=2 width=168><TBODY><TR><TD vAlign=top>
</TD></TR></TBODY></TABLE>While Lingenfelter lists the $1400 Corsa exhaust that was fitted to this siege engine as a separate option, go ahead and consider that a necessary expense. It’s so good we can’t share with you how good it is: Its assault on our audio equipment was so fierce that we couldn’t get a reasonable recording to share. Just imagine the sound of a demon with a pair of V-8s for lungs sucking your eardrums through one of those large-volume straws you get at Burger King. (Easy, right?) At idle, you can practically hear individual combustion events, and the rollicking blub blubblub blub blub already will have the faint of heart reconsidering their decision to strap in. The way the LSA rocks the car at stoplights isn’t a T-Rex-walking-by, muscle-car shimmy, but it’s still a pleasant throwback.
Hold On to Something, We’re Going Hypersonic
But no worthy pilot drives a 700-hp car for its idle. That output isn’t just a reality check, it’s a gut check. With the stock six-speed manual slotted into first gear, throttle inputs of more than 70 percent or so get earmarked for tire smoke, but once this raging machine gets traction, it reels in the horizon like few other cars on the road. The test results might be a bit misleading: the Lingenfelter’s 3.9-second 0-to-60 time is no better than the best we recorded from a stock CTS-V coupe (with the six-speed automatic), and the 11.8-second quarter-mile bests that car by only 0.4 second. But the seven-mph increase in trap speed is telling. From 60 mph to 140, the Lingenfelter CTS-V virtually mirrors the 10-mph increment times of one of the industry’s reigning accelerative champions, the Porsche 911 Turbo. A 700-hp tuned car matching Porsche’s factory effort may not seem like a big deal, but the CTS-V is heavier by about 700 pounds. Besides, the Porsche costs a lot more and it doesn’t sound at all like a demon.
<TABLE class=default border=0 cellSpacing=0 cellPadding=2 width=444><TBODY><TR><TD vAlign=top>
</TD></TR></TBODY></TABLE>From the driver’s seat, pushing the Lingenfelter feels abusive. The modified LSA makes so much power at 4000 rpm that the driver feels like as if a shift should be imminent (it betters the stock CTS-V’s 556 peak hp from 4300 rpm on), but Lingenfelter’s changes to the engine raise its redline from the stock 6200 rpm to 6800. What the company hasn’t done is change the programming of the shift lights surrounding the tach—engineers tell us they’re looking into it—which start blinking as the normal car’s redline nears. So after being crushed, wide-eyed, into the seat for a mind-altering pull through each gear, you have to ignore the shift light for a prolonged period. (Compulsive feints toward the shifter at first blink are forgivable.)
Again, there are incredible numbers behind these awe-inspiring feats. From 2000 rpm until about 6600, this car puts out more torque than the stock V does at its 3800-rpm, 551-lb-ft peak. Lingenfelter’s LSA makes more than 600 lb-ft from about 2200 rpm to 5900 or so. And from around 2400 rpm all the way to 5000, it’s generating more than 650 lb-ft of grunt. This engine doesn’t so much have a torque curve as it has a straight line across the dyno chart—a very high, straight line.
Six Gears, Most of Them Extraneous
At highway speeds, downshifting will get you to higher speeds in a hurry, but it is entirely optional. Notice how the car is actually 1.4 seconds faster from 50–70 mph than it is from 30–50 (this test is performed with the car in top gear). The engine is just hitting its stride at 70; while we don’t formally record results for higher speeds in that test, the 70–90 and 90–110 times follow a similar pattern—even in sixth, the pull of this engine is addicting. You don’t need cruise control for comfort, you need it because a lazy flex of the ankle could land you in the back seat of a police cruiser. It’s another reason to go with the Corsa exhaust: No change in engine load goes unnoticed.
As Hennessey did with the 707-hp CTS-V sedan we recently tested, Lingenfelter left the chassis unmodified. While the thought of throwing a 700-hp car into a sharp bend might seem imposing, the Lingenfelter CTS-V is incredibly tractable. (We even drove it in the rain and didn’t die.) Cranking on the wheel while stomping on the accelerator at corner entry is not recommended unless you’ve got an EMT fetish, but once the car settles in a curve, you can feed it surprising amounts of throttle alarmingly early without getting out of sorts. On the skidpad, this car bested the stock V coupe by 0.02 g, with a 0.92 performance. And the repeatability of the 156-foot stop from 70 mph is welcome, as the next corner will be coming up in a hurry.
The CTS-V coupe’s base price of $64,535 and the cost of entry for the Lingenfelter bits means that you could be sitting behind the wheel of your own 700-hp Cadillac for just $76,005. In addition to a couple of extras installed at the factory, the car tested here sported a few of Lingenfelter’s add-ons, including the mean black-anodized aluminum pedals and aforementioned exhaust system that represent an additional $1570 and shouldn’t be considered optional. Big-ticket items included a Lingenfelter carbon-fiber engine cover for $1195 and a laser-etched shock-tower brace for $350. Add in a carbon-fiber intake tube ($90), chrome Lingenfelter fender badges ($44) and license-plate frame ($35), and Brembo brake fluid ($36), and you’re looking at $80,915.
Horsepower: A Better Investment than a Hyundai
That price could put you in a BMW 6-series, a Porsche 911 (without turbos), or a Jaguar XK, none of which is half as frightening or awe-inspiring as the Lingenfelter CTS-V. Or, if you’ve already got a CTS-V, the $11,470 cost of the Lingenfelter package could buy the kids a nice used car. But if it were our family, we’d get the kids a Huffy and spend that money on horsepower. Come to think of it, we’re starting to take our 556-hp long-term CTS-V wagon for granted. We could probably use a reality check.
The End or a New Begining ? I know that I can't afford one, but I'd really love to
test drive one....Yes, I dream a lot 4-Sure...
What do you think of this Hot Rod Caddy ? Post & let us know `OK...
Old Jun 11, 2011 | 06:05 AM
Below for those MCF Member's that may want more information/pic's/vid's
<LI class="g knavi">
<TABLE style="WIDTH: auto" class=ts><TBODY><TR><TD colSpan=2>YouTube - Lingenfelter 700HP+ Cadillac CTS-V Coupe
<BUTTON class=vspib type=submit></BUTTON> <TR><TD style="PADDING-RIGHT: 8px; PADDING-TOP: 4px" vAlign=top width="1%">
<TD style="PADDING-TOP: 2px" vAlign=top>4 min - Jan 4, 2011 - Uploaded by LingenfelterVideo
Lingenfelter upgrades the 2011 Cadillac CTS-V coupe with cnc ported cylinder heads, GT9 camshaft, supercharger upgrades and fuel ...
<CITE>www.youtube.com/watch?v=43SgVt5OW4E</CITE>
More videos for 2011 Lingenfelter Cadillac CTS-V Coupe »
Lingenfelter Performance Cadillac CTS V Coupe 2011 Pictures ...
<BUTTON class=vspib type=submit></BUTTON> Lingenfelter Performance Cadillac CTS V Coupe 2011 Pictures. The Cadillac CTS V Coupe is converted by Lingenfelter.
<CITE>www.modifiedcars.com › carslingenfelter performancecadillac</CITE> - Cached
Video: Lingenfelter's 700-Plus-HP Cadillac CTS-V Coupe On The Dyno
<BUTTON class=vspib type=submit></BUTTON> Jan 21, 2011 ... Lingenfelter 2011 Cadillac CTS-V Coupe on the dyno. With both baseline and after -modification dynos in this video, Lingenfelter puts their ...
<CITE>www.motorauthority.com/.../1054066_video-lingenfelters-700-plus-hp- cadillac-cts-v-coupe-on-the-dyno</CITE> - Cached
2011 Cadillac CTS-V by Lingenfelter - Top Speed
<BUTTON class=vspib type=submit></BUTTON> Lingenfelter is world-renowned for pushing the limits on horsepower and their new engine package for the 2009-2011 Cadillac CTS-V (and new CTS-V Coupe) is ...
<CITE>www.topspeed.com/.../cadillac/2011-cadillac-cts-v-by-lingenfelter-ar103719. html</CITE> - Cached
Lingenfelter Performance 2011 Cadillac CTS V Coupe | MOTORPIX
<BUTTON class=vspib type=submit></BUTTON> Lingenfelter Performance 2011 Cadillac CTS V Coupe Pic #213917 · Lingenfelter Performance 2011 Cadillac CTS V Coupe Pic #213918 · Lingenfelter Performance ...
<CITE>www.motorpix.com › carscadillac</CITE> - Cached
<BUTTON class=vspib type=submit></BUTTON> 2011 - 02 - 17. 2011 Cadillac CTS-V by Lingenfelter. In any body variation - sedan, coupe or sport wagon, the Cadillac CTS-V models are powered by a 6.2 ...
<CITE>www.cadillacfuture.com/2011</CITE>
Old Jun 11, 2011 | 06:17 AM
drjesus616's Avatar
Originally Posted by KidSpace
license plates - "NOUCANT" and a separate credit card for gas and tires
on a side note ... i sat in a cts coupe when they first became available ... and instantly fell deeply in love, to have it with a 5 speed, and 700HP
Old Jun 11, 2011 | 06:39 AM
LoL DrJesus "NoYouCan't", but "I-Want2" 4-Sure
Here is comes
Cadillac CTS-V Black Diamond Edition
2011 - 02 - 07
<!-- p>!: Click to Enlarge!</p --><!-- bodypostbegin -->
Old Jun 11, 2011 | 06:47 AM
I'll take 2!
Old Jun 11, 2011 | 06:53 AM
LOL Mod `Mike,
With your new super `Job & New HIGH Salary you should also get one for `Taz : )
I couldn't even afford to pay for the Insurance on that Monster, let alone new tires every Week : )
Old Jun 11, 2011 | 06:57 AM
I just couldn't imagine having all that car.
I'm used to power or comfort, not both haha
Old Jun 11, 2011 | 07:05 AM
In my honest opinion. I like the idea of 700 horsepower. Who doesn't? But I've seen the CTS-V in person. The casino I work at gave one away earlier this year. I just don't like the look of the CTS-V. They put a Cadillac body onto a Corvette drive train.
I'd much rather have the Corvette body. I don't like Cadillac's headlights for one thing. Those verticle rectangular headlights are ugly in my opinion. And the exterior body lines just don't work for me.
I do like the Cadillac interior though. I'll give it that. If they offered the 700 hp Lingenfelter package in the Corvette, I'd prefer that instead.
I'm not disagreeing for the sake of being different. Just my honest opinion.
Old Jun 11, 2011 | 07:11 AM
That's OK `Lou, we won't get you one now We will change our Xmas gift to a ZR`1 Corvette instead...
Member's please send your donations for "Taz's Xmas Gift" to Space.....
<TABLE><TBODY><TR><TD>
</TD><TD id=product-price-rating-desc>$27 online
<SCRIPT type=text/javascript> var locale = 'en-us'; window.__GOOGLEAPIS = window.__GOOGLEAPIS || {}; window.__GOOGLEAPIS.gwidget = window.__GOOGLEAPIS.gwidget || {}; window.__GOOGLEAPIS.gwidget.lang = locale; </SCRIPT><IFRAME style="POSITION: static; WIDTH: 82px; HEIGHT: 20px; VISIBILITY: visible; TOP: 0px; LEFT: 0px" id=I1_1307794140497 tabIndex=-1 marginHeight=0 src="https://plusone.google.com/u/0/_/+1/button?source=shopping%3Aproductpage&hl=en-us&gcv=gcm_01fa0dcbd17f41ae40e2e164313785ce.js&jsh =s%3Bplusone%3Agoogleapis.client%4021553333_3732a1 4d%2Fclient%3Bgoogleapis.proxy%4021553333_3732a14d %2Fproxy%3Bplusone%3Agoogleapis.client%3Aiframes-styles-bubble%4021553333_3732a14d%2Fbubble%3Biframes-styles-bubble!plusone%3Agoogleapis.client%4021553333_3732 a14d%2Fbubble_only%3Bplusone-unsupported%4021553333_3732a14d%2Funsupported#url= http%3A%2F%2Fwww.google.com%2Fproducts%2Fcatalog%3 Fcid%3D13393232049075296030&size=medium&count=true &id=I1_1307794140497&parent=http%3A%2F%2Fwww.googl e.com&rpctoken=755103817&_methods=_ready%2C_close% 2C_open%2C_resizeMe" frameBorder=0 width="100%" allowTransparency name=I1_1307794140497 marginWidth=0 scrolling=no></IFRAME>
<SCRIPT type=text/javascript> var pp_url_path = 'http://www.google.com/products/catalog?cid=13393232049075296030'; if (gbar.lPWF) { gbar.lPWF(function() { gapi.plusone.render('shopping-plusone-count', {size: 'medium', count: 'true', href: pp_url_path, source: 'shopping:productpage'}); }); } </SCRIPT>
This is a very highly detailed 2009 Chevrolet Corvette ZR1 diecast model car 1:18 scale die cast by Jada Toys. Every details are well put together. Great collectible or gift piece. 2009 Chevrolet Corvette ZR1 diecast model car 1:18 scale die cast by Jada Toys is one of the best showcase model for any auto enthusiasts.
OR
Old Jun 11, 2011 | 07:17 AM
So my choice is either an $81,000 car I don't like, or a $27 hot wheels car?
You're all heart.
