= 2015 Cadillac ATS Coupe 3.6 (GM should make a new Monte on this platform ?)=
Old Oct 17, 2014 | 07:20 AM
Thumbs up = 2015 Cadillac ATS Coupe 3.6 (GM should make a new Monte on this platform ?)=
INSTRUMENTED TEST
arrow
What would John Keats drive?
When the poet John Keats suggested that “a thing of beauty is a joy forever,” it could well have been a description of the new Cadillac ATS coupe—had it not been published in 1818.
Even with a Ouija board, we’ll never know whether Keats was given to prophecy. But in the case of the ATS we can augment Mr. Keats with this corollary: a thing of beauty is more of a joy if it goes fast, thrives on switchbacks, stops in a hurry, and generates a compelling bond with its driver.
The ATS answers positively to all of the above, and anyone who fails to see beauty in this sporty variant needs to visit an optometrist. Soon.
SEDUCTIVE V-6
The coupe rolls onto the scene with two engine options—a 272-hp 2.0-liter turbo four-cylinder (standard) and a 321-hp 3.6-liter naturally aspirated V-6, both nourished by direct fuel injection. The two-door model escapes the (disappointingly mundane) base ATS sedan’s 2.5-liter four. The turbo four actually huffs up a little more torque (295 lb-ft versus 275), but the V-6 vectors a bigger herd of ponies to the rear wheels.
In an age of long-stroke engine designs, Cadillac’s V-6 is something of an anomaly: Oversquare (94-mm bore, 85.6-mm stroke) and willing to rev (6800-rpm power peak, 7200-rpm redline), it delivers no-lag throttle response and makes seductive noises as the tach needle spins. Even better, it does all this on regular fuel despite an 11.5:1 compression ratio, thanks to direct injection.
This translates into 18 mpg city and 28 highway on the EPA dynos, and we were pleasantly surprised when, at the conclusion of vigorous testing, we’d recorded 26 mpg. More gratifyingly, we also logged 0 to 60 mph in 5.4 seconds, a quarter-mile run of 14 seconds flat at 102 mph, and a top speed of 146 mph.
Those numbers stack up pretty well versus competition from the Teutonic trio that has long set the pace in the luxo sports coupe (and sedan) biz.
FANCY DANCER
More important, the two-door ATS also does better than hold its own in terms of fancy footwork. High chassis rigidity, a firm suspension (GM’s Magnetic Ride Control), a slightly wider front and rear track than the sedan’s, and quick (2.7 turns lock-to-lock) ZF rack-mounted electric steering combine to provide the sense of connection that prompts drivers to seek the long way home and sends them forth on lengthy weekend forays with no particular destination.
Our test car wore Bridgestone Potenza RE050A RFT summer performance run-flats, staggered front to rear (sized 225/40 and 255/35), on 18-inch aluminum wheels. The combo yielded impressive skidpad grip (0.91 g) and contributed to strong braking performance. In repeated 70-to-0-mph stops, we recorded only six feet of difference between shortest (162 feet) and longest (168), the latter coming first, when the brakes were cold. We recorded no trace of fade.
The little Caddy exhibits gunfighter-quick reflexes, minimal body motions, and nicely weighted steering, although it could benefit from a little more on-center feel. There’s moderate understeer near the limits of adhesion, although those limits are quite high. A minor downside here: Although the suspension is well tuned for athletic responses, it can feel overly stiff, a trait magnified by the run-flat tires, provoking some head toss on gnarly pavement.
While a manual transmission option is limited to the four-cylinder turbo, the six-speed automatic isn’t exactly a comedown. In manual mode, it doesn’t ram shifts home with the authority of, say, an Audi DSG but it’s close, and the transmission will hold shifts against redline—no autonomous upshifting. It also matches revs on downshifts, and it’s seamless in full auto mode.
MEASURE FOR MEASURE
Weak points? Not many. The rear seat is set up for only two, and if those two are tall their heads will scrape the ceiling. (Solution: Make sure all your friends are under five-foot-ten. Facebook friends exempted.) The front buckets complement a well-appointed, handsomely designed interior, but for a car capable of 0.91 g in cornering, the bolsters should be more pronounced, particularly at the torso. We’re expecting Recaros when the ATS-V is revealed at the L.A. show in November, but this car already performs well enough to warrant more support.
Beyond that, there’s the frustrating CUE touch-screen system, of which Cadillac seems so strangely proud. Don’t forget the ambitious pricing (the 3.6 starts $7155 higher than the 2.0T), but get used to it: Johan de Nysschen, Cadillac’s new boss, doesn’t want the division’s products to be perceived as cut-rate luxury.
Will the ATS stand its ground against luxury-coupe contenders? In our 2012 mano-a-mano sedan comparo—BMW 328i versus ATS 2.0T—the Caddy finished second. But this is a different game with a different body style and a different powertrain.
Considered on its own merits, the ATS 3.6 measures up as an elegant blend of athletic style, gratifying performance, and technical sophistication. It may lack the cachet of a BMW, but it’s a thing of beauty in its own right. We bet Mr. Keats would find joy in it. View Photo Gallery
PHOTOS (37)
Old Oct 17, 2014 | 07:22 AM
Thumbs up >specifications <
SPECIFICATIONS
VEHICLE TYPE: front-engine, rear-wheel-drive, 4-passenger, 2-door coupe
PRICE AS TESTED: $53,610 (base price: $46,145)
NEED a Chevy Monte Carlo for $25 K to $35K ?
ENGINE TYPE: DOHC 24-valve V-6 aluminum block and heads, direct fuel injection
Displacement: 217 cu in, 3564 cc
Power: 321 hp @ 6800 rpm
Torque: 275 lb-ft @ 4800 rpm
TRANSMISSION: 6-speed automatic with manual shifting mode
DIMENSIONS:
Wheelbase: 109.3 in
Length: 183.6 in
Width: 72.5 in Height: 54.8 in
Curb weight: 3565 lb
C/D TEST RESULTS:
Zero to 60 mph: 5.4 sec
Zero to 100 mph: 13.3 sec
Zero to 130 mph: 25.1 sec
Street start, 5-60 mph: 5.7 sec
Top gear, 30-50 mph: 3.1 sec
Top gear, 50-70 mph: 3.8 sec
Standing ¼-mile: 14.0 sec @ 102 mph
Top speed (drag limited): 146 mph
Braking, 70-0 mph: 163 ft
Roadholding, 300-ft-dia skidpad: 0.91 g
FUEL ECONOMY:
EPA city/highway: 18/28 mpg
C/D observed: 26 mpg
Old Oct 17, 2014 | 07:46 AM
Thumbs up So much 2 See/Read > so little time > EnJoy `Now<
First Drive Review
2015 Ford F-150 A beer can powered by a soda bottle.
ERIC TINGWALL | October 2014
VIEW PHOTOS (60) READ FULL STORY
First Drive Review
2015 Honda CR-V A new grille, a new direct-injected engine, and a new transmission.
TONY QUIROGA | September 2014
VIEW PHOTOS (46) READ FULL STORY
First Drive Review
2015 GMC Canyon Mid-size utility without the full-size commitment.
ANDREW WENDLER | September 2014
VIEW PHOTOS (41) READ FULL STORY
First Drive Review
2015 Porsche Cayenne Turbo "Turbo" used to strictly mean "turbo." Now it also means "more cylinders."
DAVEY G. JOHNSON | September 2014
VIEW PHOTOS (31) READ FULL STORY
First Drive Review
2015 Porsche Cayenne S The S's midcycle update sees a switch to six-cylinder power.
VIEW PHOTOS (30) READ FULL STORY
First Drive Review
2015 Chevrolet Colorado We put the spurs to Chevy's new mid-size pickup.
VIEW PHOTOS (51) READ FULL STORY
Old Oct 17, 2014 | 09:07 AM
Talking Did U ever have one ? Drive One ? What is it ?
Oldsmobile Toronado
A giant 400 horsepower, two-and-a-half-ton Mini is a gas, but it's not for citizens with cardiac conditions.
From the April 1968 Issue of Car and Driver
Luxury isn't enough in the luxury car field anymore.
It simply won't do to say, "My luxury car has more trick stuff than your luxury car," and so Oldsmobile's Toronado with its manufactured, Spanish-sounding name should be the last word in the neighbor­hood one-upmanship contest. After all, snow tires on the front have to be worth at least three points in establishing you as the Jones everyone has to keep up with.
The Toronado mystique—which began by being highly touted, found itself buried beneath comparisons to ordinary, every-clay cars that we all know and love, and is now just barely becoming touted again—centers around its front-wheel-drive sys­tem.
One of Oldsmobile's problems in toutistry of fwd is that it's great to blather about, but it doesn't seem to be generally understood. The advantages of locating the engine and driving wheels on the same end of the car are fairly obvious. More weight on the driving wheels for traction and the absence of driveline tunnels intrud­ing on passenger compartment space are desirable features in any automobile.
The problem then is simply choosing the right end. Engine in the rear presents the least mechanical problems since the driven wheels will not be required to steer. But, distinct stability advantages result from lo­cating the weight forward. A car in mo­tion is very much like an arrow in flight. Imagine a tail-heavy arrow or, to be closer to the subject, a VW in a crosswind. Since the arrow analogy establishes a better than good case for fwd, will there be any dis­advantages other than cost? Sadly, yes. Whenever the most heavily loaded pair of tires is also the driven set there will be a certain reduction in ultimate cornering ability. This applies only to passenger cars where the same size wheels and tires are used both front and rear.
Now in fwd cars, front tires are expect­ed not only to carry more than their share of the load and supply all of the tractive force, but also to do the steering. As a result, the cars normally have pe­culiar handling characteristics and extraor­dinary front tire wear.
Knowing the principles, it comes as no surprise to find the Toronado performing exactly as expected.
The popular fwd cars in the world: the BMC Mini, the MG 1275, and the Renault R-16, are economy cars designed to make the best use of available space. Their box­like bodies allow maximum usable passen­ger space, they have flat floors and a rear suspension design that does not intrude on luggage space. Not so the Toronado. To carve a notch out of the Thunderbird/Riviera market, Oldsmobile has chosen a unique approach. Attractive styling—probably the most important single commodity in this price class—precludes the use of the boxy shape. And right away, there goes one of the most significant advantages of the fwd concept: large passenger and luggage space. Happily for Oldsmobile, that in itself is not a serious loss in the Toronado's marketing slot. On the other hand, what's left? Good directional stability with pe­culiar handling and a flat floor—and that is precisely the difference between a Toronado and the more conventional automo­biles it competes against.
Our test car was the Ultimate Weapon from the Oldsmobile camp. Every avail­able option had been screwed, clamped, or bolted on at the Toronado works. Disc brakes, radial ply tires, Comfortron air conditioner, automatic speed control, stereo tape player, power bucket seats, electric windows all came along with the test car to warm us, cool us or confuse us. With them came a 400-hp Force-Air engine to keep everything in motion. And too, there was: tinted glass, head restraints, transis­torized ignition, chrome wheels, tilt steer­ing wheel, paint stripes and the list goes on. Come on, admit it. Our Toronado had more trick stuff than your car. It had to. The list kept going right up to $7,023.07 and 4655 pounds. Now are you convinced? You aren't? Maybe you'd like to hear about the sneaky little horn ring they've concealed inside the steering wheel rim. Wonderful device. All you have to do is squeeze it and it beeps. Never fails to go off when maneuvering into a tight parking spot or crawling in or out of the car. You could offend fewer people with rough, chapped hands or greyer than grey laundry.
When we heard about the optional 400-hp Force-Air engine we knew that nothing less would do: 455 cubic inches with dual, exhausts, high performance cam­shaft, and fresh, outside air stuffed right up its air cleaner snorkle is a hard pack­age to resist. We were right, it was great. Started and ran with never a temperamen­tal moment and even broadcast a slightly irresponsible exhaust note just to assure the world of its presence. Still, regardless of engine size, neck-snapping acceleration can't be expected from a 4600-lb. car so we were satisfied with 15.7 second standing start quarter-mile times at 89.8 mph. Not inspiring but then it shouldn't alarm your insurance company either. Continued... <Click (your choice)PHOTOS (7)Specifications >
VEHICLE TYPE: front-engine, front-wheel-drive, 5-passenger coupe
PRICE AS TESTED: $7,023.07
ENGINE TYPE: pushrod water-cooled V-8, cast iron block and heads
Displacement: 455 cu in, 7450 cc
Power: 400 hp @ 4800 rpm
Torque: 500 lb-ft @ 3200 rpm
TRANSMISSION: 3-speed automatic
DIMENSIONS:
Wheelbase: 119.0 in
Length: 211.6 in
Width: 76.4 in Height: 52.8 in
Curb weight: 4655 lb
C/D TEST RESULTS:
Zero to 60 mph: 7.7 sec
Zero to 100 mph: 21.0 sec
Standing ¼-mile: 15.7 sec @ 89.8 mph
Top speed (estimated): 129 mph
Braking, 80-0 mph: 238 ft
FUEL ECONOMY:
C/D observed: 10-13 mpg
Old Oct 17, 2014 | 10:01 PM
Red Monte Carlo's Avatar
No the monte should have a v8!
Old Oct 18, 2014 | 07:30 AM
Cool GM = Give More ?
4-warded 2 GM
Old Oct 18, 2014 | 03:17 PM
Habbibie's Avatar
ATS is too small to make a Monte out of it. Monte Carlo has always been a mid to large size coupe, if anything the Monte should a coupe version of the XTS
Old Oct 18, 2014 | 03:34 PM
Good Point...Maybe the CTS - V then (?)...
Thanks for your input/post & sharing
I just hope that GM doesn't bring back the Monte Carlo nameplate & put it on something like the below
Attached Thumbnails = 2015 Cadillac ATS Coupe 3.6 (GM should make a new Monte on this platform ?)=-cq5dam_web_1280_1280-14-.jpg
BeachBumMike
Feb 23, 2015 08:36 AM
Dec 18, 2014 05:03 PM
Sep 9, 2014 07:22 AM
BeachBumMike
Aug 6, 2014 01:30 PM
Monte_Man04
Feb 4, 2014 07:03 PM
