== 0-60 in 2.7 sec's = =
Old Dec 14, 2011 | 08:05 AM
Talking == 0-60 in 2.7 sec's = =
2013 Nissan GT-R Caught Testing In Japan, 0-60 in 2.72s: Video
A 2013 Nissan GT-R, testing in Japan
<!-- start signup_box -->On paper, the 2013 Nissan GT-R looks to be a solid improvement over the outgoing model. There’s a jump to 545 horsepower and 463 lb.-ft. of torque, from last year’s 520 hp and 451 lb.-ft., which should allow the new car to run the quarter mile in the high tens.
Nissan has been estimating that the new GT-R will sprint from 0 to 60 mph in around 2.7 seconds, and now Motor Trend has unearthed a video documenting Nissan’s performance claims. Would you believe a 0 to 100 kph (62 mph) time of 2.84 seconds, backing up Nissan’s claims of a 2.7 second 0 to 60 time? Actually, the recorded time to sixty miles per hour was 2.72 seconds, but we're willing to round to the nearest tenth.
The video is unofficial, and Nissan isn’t showing its cards just yet. Still, there’s no denying that the next generation of Godzilla will be even more formidable than the car it replaces, and the current GT-R is no slouch in the performance department.
Until Nissan shows us the new GT-R flexing its muscles, you’ll have to be content with the “bootleg” video below, shot at Sendai Highland Raceway by the Japanese website Love Cars.
MY12(US2013) GT-R 0-60mph time is...2.XXsec!!!! - YouTube
Click above link 2 watch test vid
******Found by BeachBum`Mike & wanted 2 share..
Member's, what do U think of the new GT-R ?
Would U want one ? Like 2 test drive one ?
Post your thoughts/opinions EnJoy
Old Dec 14, 2011 | 08:07 AM
Cool
2013 Nissan GT-R Revealed, Packs More Power And New Aero
2013 Nissan GT-R (Japanese spec)
<!-- social --><FORM class=subscription-form method=post action=/blocks/mail-chimp-email-subscription/subscribeEmail>
</FORM>
<!-- start signup_box -->Nissan has taken the wraps off an updated version of its GT-R supercar, which is set to debut later this month at the 2011 Tokyo Motor Show.
The new car has only been revealed in its Japanese spec, but this is the model that will be sold elsewhere around the globe early next year as the 2013 Nissan GT-R.
First and foremost, the car is getting a power boost that sees output from its twin-turbocharged 3.8-liter engine rise to 542 horsepower at 6,400 rpm and 466 pound-feet of torque at 3,200 rpm. Best of all, that torque will plateau from 3,200 revs all the way up to 5,800.
At the same time, engine response and torque at mid- and low-speeds, and power at high revolutions, has been significantly improved, but Nissan also claims that the car has been made even more fuel efficient. Final EPA numbers aren’t expected until closer to the new GT-R’s local launch next year.
The improvements are mostly due thanks to improved intake efficiency. Air flow resistance, for example, has been reduced by adding an intake manifold fitted to the head of each unit and the use of special resin in the enlarged air intake duct for the intercooler.
Air flow resistance has also been reduced through a more compact underfloor catalyzer, which improves emissions efficiency and reduces weight. Finally, for improved exhaust valve cooling performance, a newly-designed metallic sodium-filled valve has been adopted. Valve control timing, the air mixture ratio and ignition timing have all been improved as well.
The transmission also gets some upgrades to deal with the extra power. Shift feel and noise have been refined through a strengthened design of the shift fork arm and a firmer fixing bearing for the flywheel housing. A high-performance differential oil (R35 COMPETITION type 2189E 75W140), which has been used in motorsports, has also been made standard across the line.
But it’s not just about brute force as the 2013 Nissan GT-R has also been fitted with asymmetric suspension, meaning the design has been readjusted to compensate for the weight of the driver and steering column--just like in a race car. Additionally, more reinforcing, mainly around the rear part of the engine compartment and dash panel, improves cornering stability and provides the driver with a greater sense of road-holding ability.
For the front suspension, a harder spring rate on the left side has been set. For the rear, the suspension arm has been installed upward on the left side and downward on the right for an imbalanced wheel load when the car is stationary, but is equalized during driving, providing improved responsiveness and smoothness which the driver feels when steering, as well as enhanced cornering stability and riding comfort. Note, it’s not clear yet whether this design will only be used on right-hand drive models or featured globally.
Jointly developed with Japanese firm NordRing, a new Track Pack edition is also available and features stiffer suspension, an air guide for brake cooling (front and rear), and aluminum-alloy wheels made by Rays (with black quartz chrome color coating). There’s also a host of aero upgrades including a new front spoiler with carbon fiber air duct that has been exclusively made for this edition and is installed as a set.
For reducing the car's weight, this edition is made in a two-seat configuration, with the rear buckets removed and the front two replaced with lighter racing seats trimmed in a high-grip fabric. Another worthy option is a new carbon ceramic brake package that is likely to be offered in markets outside Japan.
With more power under the hood, a lighter and stiffer body, plus a host of new aero upgrades, reports of the GT-R shaving 8 to 10 seconds off its previous Nurburgring lap time now sound completely plausible. Nissan is also claiming that the car’s 0-60 mph time has dropped to just 2.72 seconds.
As mentioned, many of these specs are for the Japanese model. More details on the U.S. delivered 2013 Nissan GT-R should be revealed closer to the car's launch early next year. In the meantime, stay tuned for a world debut at the 2011 Tokyo Motor Show, press days for which kick off on November 30.
<!-- rendering content took 21.764039993286ms -->
HI-RES GALLERY: 2013 Nissan GT-R (Japanese spec)
Old Dec 14, 2011 | 08:29 AM
Below are some other Rides that do 0-60 in under 3 seconds Which one do U want ?
  1. 0 to 60 mph - Wikipedia, the free encyclopedia
  1. <CITE>en.wikipedia.org/wiki/0_to_60_mph</CITE>Cached - Similar
  2. ... in under 6 seconds, while exotic cars can do 0 to 60 mph in between 3 and 4 ... Automobile magazines often post 0-60 mph times that they achieve in testing. ...
  3. New RC Car Hits 0-60 In Under Three Seconds - Mobile Magazine
    <CITE>New RC Car Hits 0-60 In Under Three Seconds - Mobile Magazinecar-hits-0-60-in-under-three-second...</CITE>Cached
    Dec 1, 2011 – New RC Car Hits 0-60 In Under Three Seconds ... is capable of going from 0- 60MPH in just 2.3 seconds and can hit 100MPH in 4.92 seconds. ...
<LI class=g><TABLE style="WIDTH: auto" class=ts><TBODY><TR><TD colSpan=2>
  1. 0-60 MPH in 3 Seconds, running E85 Flex Fuel - YouTube
<TR><TD style="PADDING-RIGHT: 8px; PADDING-TOP: 4px" vAlign=top width="1%">
► 1:12► 1:12
<TD style="PADDING-TOP: 1px" vAlign=top><CITE class=kv>www.youtube.com/watch?v=xx6FtWEzFzI</CITE>Sep 4, 2008 - 1 min - Uploaded by StrayTheNomad
0-60 MPH in 3 Seconds, running E85 Flex Fuel. StrayTheNomad ... What kind of exhaust setup do you have ...
</TD></TR></TBODY></TABLE>
<LI class=g><TABLE style="WIDTH: auto" class=ts><TBODY><TR><TD colSpan=2>Wrightspeed X1 0-60 in less than 3 seconds - YouTube
► 0:52► 0:52
<TD style="PADDING-TOP: 1px" vAlign=top><CITE class=kv>www.youtube.com/watch?v=1n7m2_LEQ-k</CITE>Jul 5, 2006 - 52 sec - Uploaded by joelklabo
Wrightspeed X1 0-60 in less than 3 seconds. joelklabo 9 videos ... Can you imagine a traffic jam with ...
  1. More videos for What cars do 0-60 in under three seconds »
  1. <LI class=g>A Green Muscle Car? 110 MPG Mustang does 0-60 in 3 Seconds ...
    <CITE>masslogics.com/a-green-muscle-car-110-mpg-mustang-does-0-60-in-...</CITE>Cached - Similar
    Jul 3, 2008 – This 400 horsepower muscle car does 0-60 in under 3 seconds and a top speed of about 180 MPH. Even more amazing, the car gets 110 MPG. ...
    <LI class=g>McLaren MP4-12C can run 0-60 mph in under 3 seconds with ...
    <CITE>www.egmcartech.com/.../mclaren-mp4-12c-can-run-0-60-mph-in-un...</CITE>Cached - Similar
    Mar 21, 2010 – Along with its ambitions to take on the supercar market, McLaren officially launched the MP4-12C earlier this week. However, McLaren has yet ...
    <LI class=g>Sports Car : The Ariel Atom 0-60 mph in 2.7 seconds | Dream Road
    <CITE>www.dreamroad.us/sports-car-the-ariel-atom-0-60-mph-in-2-7-secon...</CITE>Cached
    Aug 31, 2011 – There are three Ariel Atom incarnations to date: Ariel Atom Ariel Atom Ariel ... The car is also manufactured under license in the United States, originally ... Each of these engines can reach a speed of 0-60 mph in 2.7 seconds. ...
    <LI class=g>
    <LI class=g>
    <CITE>Sitemap - Autoblog0-60-in-2-9-s...</CITE>Cached - Similar
    Dec 2, 2010 – ... it take to accelerate from 0 to 60 mph in just under three seconds flat? ... anyone can bash this car, perhaps because we are american or for ...
  2. World's top 5 fastest street legal electric cars
    <CITE>www.gizmag.com/top-5-worlds-fastest-street-legal...car/11414/</CITE>Cached - Similar
    Apr 10, 2009 – Both vehicles can do 0-60 mph in less than 1 second but because neither are street ... 120 mph and can accelerate to 60 mph in less than 3 seconds. .... dream, but until they can fully charge an electric car in under 10 minutes, ...
Old Dec 14, 2011 | 08:33 AM
Old Dec 14, 2011 | 08:34 AM
Old Dec 14, 2011 | 09:01 AM
The GT-R is one amazing car & its the right color
Old Dec 14, 2011 | 09:33 AM
Cowboy6622's Avatar
It's amazing how far those cars have come in such a short time. Amazing piece of engineering, that car. And the price.... wow, I always said the Corvette gave more horsepower per $ than any car in the world, but that may be wrong now.
Old Dec 15, 2011 | 07:19 AM
Hi `Duane & Member's,
I am constantly amazed by all the exotic performance cars that are made around our World. I also am amazed that there is a market for these high $ dollar machines...
I can only dream about ever owning one or driving any of the above posted machines...I'm happy that there is a market for them, but I wish I was in the position to be in the market for one of them : ) I shall continue to play the Lotto & pray/dream
p.s. Thanks everyone for your posts/contributions 2 the MCF
Old Dec 15, 2011 | 08:15 AM
With how hard it is to launch an AWD car, I would imagine not many people who own this car can pull off the 2.7 sec 0-60.
Unless they have A LOT of nannies helping you.
Which is why I would still prefer the Corvette. You just get the raw horsepower control.
Old Dec 15, 2011 | 12:21 PM
04chevyboy's Avatar
This would be one fun ride to hit the highway with
moemusic
Mar 16, 2011 04:26 PM
BeachBumMike
Sep 16, 2007 06:07 PM
BeachBumMike
Jul 15, 2007 10:14 AM
BeachBumMike
Apr 17, 2007 03:48 PM
BeachBumMike
Oct 11, 2006 08:13 AM
