water leak on drivers side floor
Hi everyone, I'm new to this site as I am new to my 2004 monte carlo ls. I've been having a problem with water leaking onto the drivers side floor and I cannot figure it out. I pulled the cowel where the windshield wipers are and that drain is not clogged, I did notice that the plastic piece that is attached to the wiper motor has flattened the weather stripping down and is wet, however the drain where the rain goes is clear. I tore apart under the dash and have no sign of water, I did clear the drain holes on the bottom side of the door and water came out so I thought it was fixed. Wrong! had more rain and it gets wet right where you rest your foot and where the e-brake is. The weather stripping around the door looks good except a small tear at the back side of the door. my car is parked on a incline so I thought maybe if it is leaking there I would see it but that's not the case either. I just turned the car around in the driveway to see if that makes a difference. If anyone knows anything else I would greatly appreciate it.
I had same problem with my 2003 LS,The weather seal on top of the door all the way
forward was leaking in.I used RTV seal under it and fixed it,I used a garden hose to find
it.water will drive you crazy just keep looking and try diffrent things.
ROBF
ROBF
l0gitech87
Jun 18, 2012 05:58 AM
thefuzz
Jul 18, 2011 09:13 AM
