Monte carlo 2004 turn signal problem
That usually indicates a bad bulb. Try swapping bulbs with the other side front then rear and see if it changes. If no change, inspect the sockets and look for a rubbing wire. Have you had any issue with slow signals? That would be an indication your hazard switch is failing, if you haven't replaced it recently.
Skeletal Crow
07-22-2011 11:56 AM
