Hi everyone, I Need Transmission advice/Help/Thank You!
Old Dec 24, 2013 | 11:10 PM
l67ss's Avatar
If the impala had the same engine itll have the same gears. If not, make sure to get the pcm programmed for the current tranny. I made that mistake with my car.
Old Dec 25, 2013 | 01:09 AM
02paceSS's Avatar
the monte carlo comes with 2 different transmission options an fr9 and f83 and the gear ratios are different .can I just use the pcm out of the impala instead of getting it programmed? i have a full impala parts car
Old Dec 25, 2013 | 03:01 AM
l67ss's Avatar
Not sure on the security thing, it should run it ok if your not locked out(gen 1 ws have a separate passkey module) so im guessing the impala has a 3.4? User the maniac can reprom your pcm for the right gearing(and optimise shift points and air/fuel ratios) for i think $60+ shipping
Old Dec 25, 2013 | 01:02 PM
02paceSS's Avatar
no the impala has a 3800 also the trans are the same but with different options which means the ratios are different if you look it up you will see that that the transmission come with 2 different options for the 3800
Old Dec 25, 2013 | 01:55 PM
l67ss's Avatar
Turns you were right. Learn something new everyday. Now if you are just needing to get it running asap, go ahead and use your monte pcm. Before you drive it, unplug a couple sensors while its running(like maf) just long enough to set off the check engine lite. Do not clear codes. This will cause it to go to the last correct operating calibration and trick it into shifting better. Take the pcm from the impala and have it unlocked and install in your car. That way you can drive your car while youre waiting on proggramming. Plus gives you a lil more time to come up with $
Old Dec 25, 2013 | 04:27 PM
02paceSS's Avatar
always good to learn something new and thanks for your help I tried the computer before this message and does everything but start. hopefully I get the trans in my car soon
Old Dec 25, 2013 | 04:38 PM
l67ss's Avatar
Heres an idea, try using the ignition and key from the impala, that should bypass the security thing
Old Dec 25, 2013 | 05:24 PM
02paceSS's Avatar
ill might try that. once I get this transmission fixed will the traction light go out?
Old Dec 25, 2013 | 06:18 PM
l67ss's Avatar
Thatd b more of an issue with wheel speed sensors. Check you wheel bearings, wires running to the wheel speed sensors.
Old Dec 25, 2013 | 06:50 PM
A couple of things:
1 - It's NEVER a good idea to unplug a sensor while the car is running. They have power going to them, the PCM is getting readings. Unplugging the MAF and then starting the car well still throw a CEL.
2 - I would not bother swapping the ignition and key from the Imp. You will make things potentially worse. The theft lock is with the ignition, the BCM and PCM (I'm sure other items interact with it).
3 - If you want to try the Imp PCM, I would only do that if the Imp and the Monte had the same v6 (such as a 3400, 3800 or 3800 S/C). If the engine in the Monte is different from the one in the Imp, don't bother, the tunes for the engines will be WAY off.
4 - Also, if the engines in the cars are different, I wouldn't bother with the trans unless you have a reason to want that gearing. The 4T65 used between the 3400 and the different 3800's are different.
5 - If it is worth trying the PCM from the Imp, pop it in, try doing a "security relearn" if it doesn't start (I will post the directions at the bottom).
6 - I do offer some PCM services, but they are basic. Click this link for more info ----> https://montecarloforum.com/forum/pr...-3100-a-42773/
BTW - It takes a little research, but if I should be able to pull the trans settings from your Imp PCM (or if I have a compatible Imp PCM BIN file already) and drop those settings into the PCM for your Monte (this means you could have the Imp gear ratios, shift points and all other trans related settings packed into your Monte PCM). And I can do some other stuff too, but I don't mess with Air/Fuel ratios (refer to the link I mentioned for more info).
PCM Relearn Info:
Please read this completely before attempting to install the enclosed PCM.
These are the steps to performing a security relearn in the event the car does not start up immediately.
Notes: Security relearn procedure will not work with the valet key! Also, do NOT remove the key until the relearn is complete. When the steps state to switch the ignition to the off position, just switch to off, do not remove the key from the ignition.
Method 1:
1. Disconnect battery
2. Install new computer
3. Reconnect battery
4. Put emergency brake on to disable daytime running lights (this step is required!)
5. Make sure all doors trunk and hood are closed leave driver window down and reach in through the window
6. Try to start. If it doesn't start, leave the key in the on position for 11 min on 97-03 cars and 15 min for 04 and newer cars. The security light should turn off after this amount of time.
7. Before proceeding, verify the security light is no longer on OR that the message center is no longer flashing the security message with the other messages it's cycling (such as battery).
8. Turn off ignition for 30 seconds
9. Try and start the car. It probably won't start. Repeat step 5 two more times.
10. If this doesn't work disconnect battery for 5 seconds and then try and start the car.
Method 2:
1. Disconnect battery for 10 sec.
2. Reconnect battery
3. Turn key to ON position
4. Do not try to start vehicle, just quickly click to RUN position to engage security light
5. Let vehicle sit with key ON for 35 min.
6. Attempt to crank vehicle. Once vehicle is running, the security light may still be on
7. If security light is still on, turn key to OFF position for 5 sec.
8. Turn key to ON position and security light should turn off
9. Start vehicle and enjoy new PCM
Method 3:
1. Try to start the vehicle.
2. Turn ignition to OFF for 10 seconds.
3. Turn ON (NOT START) the ignition (using a black Master Pass-Key III key, not a gray Valet key).
4. Observe the SECURITY telltale on the dashboard. After approximately ten minutes it should turn off for the first time.
5. Turn OFF the ignition and wait for ten seconds.
6. Turn ON (NOT START) the ignition (using a black Master Pass-Key III key, not a gray Valet key).
7. Observe the SECURITY telltale on the dashboard. After approximately ten minutes it should turn off for the second time.
8. Turn OFF the ignition and wait for ten seconds.
9. Turn ON (NOT START) the ignition (using a black Master Pass-Key III key, not a gray Valet key).
10. Observe the SECURITY telltale on the dashboard. After approximately ten minutes it should turn off for the third time.
11. Turn OFF the ignition and wait for ten seconds.
12. Start the vehicle.
Notes: If your car starts at any time and stays running, you are done. If your car starts and dies, try step 9. If it dies after 2 seconds after you have done these steps, you either have a bad FP resistor or the security setting in your PCM is wrong and it will need an update.
