Clunking noise in rear wheel?
Old Apr 17, 2014 | 11:45 PM
TSauer09's Avatar
Default Clunking noise in rear wheel?
Hey all, I'm in need of some help here. I own a 1997 Monte and I've got a problem with a clunking noise coming from the rear wheel which usually happens on a rough road and while traveling on gravel. I've got an idea that it's a shock/strut, whichever the '97 Monte has. However, I'm not 100% sure and that's where I'd like your help. What could it be and what would it cost to repair?
All help is greatly appreciated. Thank you!
Old Apr 18, 2014 | 05:05 AM
Sounds like a strut mount may be the culprit. Not too spendy if you can do the labor yourself. (easy to do) ebay has the parts , a pair for $50
Monroe Strut Mate Strut Mounting Kit 902968 | eBay
Old Apr 18, 2014 | 07:21 AM
Welcome to the forum. I have to agree with zippy cause I had a close issue with my monte making the clunking noise.
Old Apr 18, 2014 | 07:28 AM
03SSLE's Avatar
Also check the muffler hangers (muffler loose) and all bushings in the rear suspension.
Old Apr 18, 2014 | 07:31 AM
Greg Is precisely right...
Its a common issue on the 5th gens...
If you haven't changed the struts out recently .. (Or not maintained at all)
It literally pounds the crap out of the upper strut mount.... If not taken care of immediately... the end result will be the Loss of the actually mounts molded into the car...and unless you know someone that can do that kind of repair... once the mount is beat literally out of the vehicle... you will find your self vehicle less...
You may want to look in the trunk and actually visually inspect thye struts body mount.... You maybe surprised what youll find! The 5th gens tend trap a lot of water in the strut body mount area and cause a lot of rusting....
In those areas... So I would definitely keep an eye on it....
1 preventative thing you can do (If its not all rusted out already) Get yourself some pors 15 and brush it in and around all the rust that's developing... It does stop rust dead in its tracks... That may help save your Monte. The only downside... Is theres also some areas that you cannot get to (Reach) that may continue rust in time... hopefully it isn't to bad and maybe prevent it from spreading thus allowing you to enjoy your Monte for Many more years to come.
Old Apr 18, 2014 | 11:16 AM
TSauer09's Avatar
Thanks for the help everyone! I will look into all of those things.
bittyx2
Dec 12, 2013 08:33 AM
Franks 03SS
Dec 30, 2011 06:52 PM
03MCLSX
Aug 20, 2010 11:54 AM
02montecarlo
May 20, 2010 09:19 PM
dom82
Mar 29, 2009 09:22 AM
