Brake light comes on and off ocassionally
Old Dec 30, 2019 | 08:06 PM
SSblack06's Avatar
Unhappy Brake light comes on and off ocassionally
I changed my pads and rotors and about a week later my brake light comes on and goes off. And the chime won't stop
Old Dec 31, 2019 | 02:45 PM
O-Five's Avatar
Have you checked your brake fluid level? I just had this type of issue with another vehicle, fluid was low.
Old Jan 1, 2020 | 11:34 AM
SSblack06's Avatar
Default Brake light
I have checked the fluid levels they are fine
Old Jan 1, 2020 | 02:48 PM
O-Five's Avatar
Is it the ABS light that comes on or what one? I have that now (ABS light on) , used a code reader. Says it is my R / rear wheel speed sensor. You could be in a similar situation. The chiming is something I do not get though.
Old Jan 1, 2020 | 06:17 PM
SSblack06's Avatar
Default Brake light
It is the brake light not the ABS
Old Jan 1, 2020 | 11:22 PM
O-Five's Avatar
So you are saying a Brake light on the dash comes on right, not a brake light in the rear liight housing. As far as I can determine there are no chimes associated with the brake system on our Montes, so that has to be something else. I still say if it is a brake light on the dash your problem is a wheel speed sensor wire or the unit itself has failed. Worse case but more rare is the ABS unit itself is failing. Is your emergency brake FULLY released? Reapply the E-brake and then insure it is fully released this time.
Anyway copied this from a site called Drivetrain Resource. Read through it and do the checks they recommend. You may have a symptom they list anmd the corrective action to perform. Actually pull off the cap from the MC to insure the fluid level is proper for front and rear divided master cylinder.
Chevy Monte Carlo Brake Warning Light: Why is it on?
September 1, 2019 by JasonYour Chevy Monte Carlo‘s brake light indicator is there to let you know that there is an issue with the brake system. It is different than the anti-lock brake system, which gets its own ABS warning light. The brake light indicates that there is a problem with the physical braking system itself.
If you are reading this article trying to figure out whether you should drive your vehicle, check the emergency brake first. If it’s engaged, the brake light will stay lit. If the handle isn’t all of the way down, it’ll cause the brake warning light to stay on. Check to make sure that there isn’t the little bit left that it needs to turn the brake light off.
Now if the emergency brake didn’t fix the situation, it’s time to look into what is causing your Monte Carlo’s brake warning light to stay on. The brake light is perhaps the most important warning light of all. We do not recommend driving with this light on at all. Doing so may lead to injury when the brakes fail.
Chevy Monte Carlo Brake Warning Light Causes
The brake warning light indicates that your Monte Carlo has detected that one of its major brake components has failed, typically detected through a loss of pressure. You’ll feel a loss of pressure that manifests itself in the form of a “mushy” brake pedal.
If the brake light is only coming on when you push the brakes, that’s a definite indication that the pressure in the brake system is too low. Either the brakes need bled, or there is a leak.
Brake Fluid Leak
Since you’ve already checked the emergency brake handle, now it’s time to check the master cylinder and see if the brake fluid is low or not. Now if it is low, but not empty, adding more may provide a temporary fix.
If the
brake fluid brake fluid
looks like it is all the way out, you’ll need to add more, bleed the brakes, and ideally fix the problem so that you aren’t repeating all of this again. If the brake fluid is leaking out over the brake pads and shoes, it means poor brake performance.
Just remember, it had to leak out somewhere, and that adding fluid without fixing the problem is just a temporary solution. The leak can get worse over time and lead to brake failure.
Report this ad
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAKQAAAAUCAMAAAA 0oWYGAAAANlBMVEUAAACkpKSkpKSkpKSkpKSkpKSkpKSkpKSkp KSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKSkpKT0RuBeAAAAEXR STlMAECAwQFBgcHuEj5+vv8/f7w0rGDcAAANcSURBVEjHzZbLlsMoDEQLMMYBPaj//9lZCDt2Oj1nZtesHCKbS0klwLFnACh9SwDQWkaM1Cj4I2OSDUA jtQAw8gUAyD6V9e9AcgA7SW6AktQEJPeMKQCaqqpKBoDDVNX2c 1JVVW0k1PUsvRUAQLOIA4BNVVUK0FRUKwBsomIdaajoyEhdRaU AQFfRkZC6yjm0wUmyBSQTlAH9YgLMAQySJHcAyUiS/ZokSc6Mdv3wUXC+1AOyne/3a/IgSUH2kCa+ewBISnKW9c8agkmSc0G+ApIFOoFEeUN2ANtcUbHe N8i1nb7iznVJWa8bAAhJ1kCZZYXMbQV7RnpCxq9SSZKWZGHIBI QbLh5NpyZvSJ8+fVpaW/TYA7cH5NrZLME2CwLOErKR9BOSCiRZkEaSM8YIJblvS5SAHGjc PXyzIM9FbpBHziWXkhe9lLL7Eu0GeYreVlgD6krNByRf4YkTct ZccsklLyUXJBekAJOyfSxS/Am5X+5rj4KY2w0yGTktdMoeBd+X3tnu6SZZcFdylru7b0qOpST KtgI6yemkoMbDBemiotpPyHFV236DrCR186AakWZb5fOpJA39n m4TUbEd35Uctx7VSfqYtHSQIj+MY+kOOT4hB8kODaV3kiz59PJ DSZ8kj3aH5Anzm5IPyNmMswp5/F/I7CQbDpKewrS1Lis/lRyNqzB+Qv4nJbkP0ia93iF9iIgej3RrNJcLcilTYhqD5OgkJX 0qqauz3NM9RMT2S8n6r0pyjyYj2X43zgBQZzTOC1JJej/GOtgqSc7w+IeSM+X5hJz5q3F+VzI+cKS7cY6Ucsr5akE575M3/76Ajc+ufzZpz/hRk+Xsw+8WlFJKKYfTyJYXZP8FMuLqA3KamZnbFoaYFgTz1sxf d0i2q5jjfvVQ0q9GfKXbYwFdbx1L0bR9h2zhn8jIx7HI/ddjMVlk+3WMdWotaSu+KYnI14dxOKOk2deyCfMTUmITe1wJvlw wWG+QM46AdcF4G+p0VBh1poCc9wtGwepRzDjLM8Z1WkRgjtK+Q zYz84piZg1J3XyPyTXcCup6VjnWVc3NfMfuZlavGavAy8183Y+ yuLkWpOHmmgFkdXPJSOLvFWRZs68LSAkD/pkr+XuUPg8AqDozgPya/W8B/gPQAm/tWHkI8wAAAABJRU5ErkJggg==[/img]
Pressure Differential Switch
Your brake system is divided into two circuits. These circuits cut the brake system in two. That way, if the brake system gets a leak or fails, you still have brakes on half of your Monte Carlo’s wheels.
The pressure differential switch measures the difference in pressure between the two circuits and will report that there is a difference by turning on your Monte Carlo’s brake warning light. In most vehicles this switch is located in the master cylinder. You’ll see a harness plug in somewhere around there.
Check the Brake Lights
Some vehicles will now activate the brake warning light on the dash if the actual brake lights behind it go bad. Check to see that both of them are lighting up. If not, try replacing the bulb and see if that solves the problem.
How to Turn off Your Monte Carlo’s Brake Light
The only way to turn the brake light off is to restore proper line pressure to both brake circuits when the pedal is pushed. If your Monte Carlo is having trouble stopping, or noticeably leaking fluid, don’t drive it. Just have it towed to a mechanic. If you mess up fixing your engine, the vehicle does not move. If you mess up fixing the brakes, it doesn’t stop. That’s infinitely more dangerous.
Conclusion
If your Chevy Monte Carlo’s brake warning light is on, and you’ve checked the emergency brake, you’ll need to look for a leak in the lines, calipers, wheel cylinders, master cylinder, etc. Good luck diagnosing the issue. If there is anything that you would like to add, please leave a comment below.
hotrodharley
Nov 15, 2013 11:37 AM
Jerry Barao
Jan 12, 2013 07:54 AM
dupree155
May 9, 2010 02:33 AM
amberblk00
Aug 7, 2008 12:16 PM
STL_CHeVY_RiDeR
Mar 17, 2008 08:36 PM
