06 Monte Carlo SS cranks but won't start
Old Mar 19, 2024 | 10:58 PM
CoinorCrest's Avatar
Default 06 Monte Carlo SS cranks but won't start
06 Monte Carlo SS cranks but won't start what should I replace I suspect anti theft how do I resolve this problem ??. Please help
Old Mar 23, 2024 | 09:48 PM
Budsjlm's Avatar
Is the security light on?
they need air fuel and spark to run,
can you hear the fuel pump run priming the system when you turn the key to the on positio?
should be a schrader valve(like a tire valve) under a cap on the fuel rail you can push in to make sure it’s getting fuel pressure after keying the car on,
check for spark, pull a spark plug wire and either use a spark tester that goes between the spark plug and wire or stick a screw driver in it lay it by a metal piece in the motor and have someone crank the car while you watch
HumbleBeast407321
Jul 21, 2021 04:51 AM
smeunier
Aug 12, 2017 12:32 PM
stretch8891
Nov 5, 2014 07:50 PM
mothewoodman@comcast.net
Jun 11, 2014 11:30 PM
Bezi99
Mar 4, 2009 10:10 AM
