02 running hotter than usual
Old Aug 19, 2015 | 04:07 PM
doeadeer's Avatar
Default 02 running hotter than usual
Hi all. Well, I know I had been a member here before, but it's been a while. So, I just re-registered!
I was reading a similar post to mine about a hot running car, but now that I've done the registering thing....I can't find that post!
I did learn that the guy re-installed the....hmmm....not sure what it's called, but it's the reflector thing that goes under the car. I'm not sure if mine is still there or not. He stated that once he put that back on, it was running at it's normal temperature. I'll have to check that.
My mechanic always tells me "it's a big engine, it will run hot". But....I know it's NOT normal. I know my car. Bought it new in '02.
Does anyone have any feedback about those radiator caps that have the pressure release thingy? Are those better than just the normal screw on only ones? I thought about changing out the cap to see if that did anything.
Any direction/comments appreciated!
Old Oct 1, 2015 | 09:14 PM
tey216's Avatar
Actually that was me.... The airdem underneath the car was off... I put it back on and the temperature went back down...
However, I have had many cars since owning my Monte and none of them do what my monte does... All my other cars the temperature gauge goes to about the halfway point and doesn't move from that point...and if it does there's a problem that requires immediate attention...
Not with the Monte though... The temperature gauge fluctuates all over the place depending on the weather but never runs hot...
I don't know if that's a good thing or a bad thing... Maybe the sensors are more sensitive than other cars or what...
Old Oct 6, 2015 | 05:00 PM
wkimes's Avatar
I have a 02 as well, and mine just runs a little over the half line.
Old Oct 6, 2015 | 08:54 PM
Welcome to the Forum..
Old Oct 7, 2015 | 12:25 PM
What have you done to remedy the problem?
Have you flushed the system?
Stock radiator caps are fine, they pressurize the system and increase the boiling point of the coolant so it doesn't boil out and run lower.
tey216
Jul 1, 2014 02:57 AM
vincenti
Jul 31, 2013 07:34 PM
02montecSS
Nov 22, 2011 05:15 PM
Tavi07SS
Oct 2, 2009 09:11 PM
moonlitmagik
Aug 27, 2009 06:11 PM
