NASCAR ?`s
RE: NASCAR ?`s
[align=center]I am still looking forward to the begining of NASCAR this year.[/align][align=center]I prefer the road courses the best, but I love all motorsports,[/align][align=center]and especially the talent of those that master `speed,[/align][align=center]and their machines[/align][align=center]To watch and see who is going to be the best of the best.[/align][align=center]I envy those that get paid to do what they love.[/align][align=center]To me that is a major ingredents to happiness, 4- Sure[/align][align=center]May the best driver/car/team win [/align][align=center] NASCAR 101[/align][align=center][:-][/align]NASCAR 101: KNowledge is Power The more one knows, the more that they can enjoy and understand the many aspects of racing, and or NASCAR. Read & Learn & EnJoy.
Learn all the strange terms you hear in NASCAR, right hereâŚ
AERO PUSH
When following another vehicle closely, the airflow off the lead vehicle does not travel across the following one(s) in a normal manner. Therefore, downforce on the front of the trailing vehicle(s) is decreased and it does not turn in the corners as well, resulting in an âaero push.â This condition is more apparent on the exit of the turns.
AERODYNAMIC DRAG
A number that is a coefficient of several factors that indicates how well a race vehicle will travel through the air and how much resistance it offers. Crewmen work to get the best âdrag horsepowerâ rating they can, determining how much horsepower it will take to move a vehicle through the air at a certain mile-per-hour rate. At faster speedways teams strive to get the lowest drag number possible for higher straightaway speeds.
AIR DAM
A strip that hangs under the front grill, very close to the ground. It helps provide downforce at the front of the car.
AIR PRESSURE
With the advent of radial tires with stiffer sidewalls, changing air pressure in the tires is used as another setup tool that is akin to adjusting spring rates in the vehicleâs suspension. An increase in air pressure raises the âspring rateâ in the tire itself and changes the vehicleâs handling characteristics. If his race vehicle was âtightâ coming off a corner, a driver might request a slight air pressure increase in the right rear tire to âloosen it up.â
BACK MARKER
A car running off the pace near the rear of the field.
BALANCE
When a car doesnât tend to oversteer or understeer, but goes around the racetrack as if its on rails, itâs said to be in balance.
BANKING
The sloping of a racetrack, particularly at a curve or a corner, from the apron to the outside wall. Degree of banking refers to the height of a racetrackâs slope at the outside edge.
CAMBER
Camber addresses the angle at which a tire makes contact with the track surface. âPositive camberâ indicates the angle of the tire is tilted away from the vehicleâs centerline while ânegative camberâ indicates the tire is tilted toward the centerline. A typical oval track setup would have positive camber in the left front and negative camber in the right front to help the vehicle make left-hand turns.
CAMSHAFT
A rotating shaft within the engine that opens and closes the intake and exhaust valves in the engine.
CHASSIS
The combination of a carâs floorboard, interior and roll cage.
CHASSIS ROLL
The up-and-down movement caused when a car travels around corners at high speeds. The said of the car facing the turn becomes lighter while the extra weight goes toward the outside of the turn.
CONTACT PATCH
The part of the tire thatâs actually touching the road.
DIRTY AIR
The air used and discarded by the lead car.
DOWNFORCE
The air pressure traveling over the surfaces of a race vehicle creates âdownforceâ or weight on that area. In order to increase corner speeds teams strive to create downforce that increases tire grip. The tradeoff for increased corner speeds derived from greater downforce is increased drag that slows straightaway speeds.
DRAFT
The aerodynamic effect that allows two or more cars traveling nose-to-tail to run faster than a single car. When one car follows closely, the one in front cuts through the air, providing less resistance for the car in back.
DRAFTING
The practice of two or more cars, while racing, to run nose-to-tail, almost touching. The lead car, by displacing the air in front of it, creates a vacuum between its rear end and the nose of the following car, actually pulling the second car along with it.
DRAG
The resistance a car experiences when passing through air at high speeds. A resisting force exerted on a car parallel to its air stream and opposite in direction to its motion.
ENGINE BLOCK
An iron casting from the manufacturer that envelopes the crankshaft, connecting rods and pistons.
FABRICATOR
A person who specializes in creating the sheet metal body of a stock car. Most teams employ two or more.
FIREWALL
A solid metal plate that separates the engine compartment from the driverâs compartment of a race car.
FRONT CLIP
The front-most part of the race car, starting with the firewall.
FUEL CELL
A holding tank for a race carâs supply of gasoline. Consists of a metal box that contains a flexible, tear-resistant bladder and foam baffling. A product of aerospace technology, itâs designed to eliminate or minimize fuel spillage.
GROOVE
Slang term for the best route around a racetrack; the most efficient or quickest way around the track for a particular driver. The âhigh grooveâ takes a car closer to the outside wall for most of a lap, while the âLow grooveâ takes a car closer to the apron than the outside wall. Road racers use the term âline.â Drivers search for a fast groove, and that has been known to change depending on track and weather conditions.
HAPPY HOUR
Slang term for the last official practice session held before an event. Usually takes place the day before the race and after all qualifying and support races have been staged.
HANDLING
Generally, a race carâs performance while racing, qualifying or practicing. How a car âHandlesâ is determined by its tires, suspension geometry, aerodynamics and other factors.
INTERVAL
The time-distance between two cars. Referred to roughly in car lengths, or precisely in seconds.
LAPPED TRAFFIC
Cars that have completed at least one full lap less than the race leader.
LOOSE
(Also referred to as âfreeâ or âoversteer.â) A condition created when the back end of the vehicle wants to overtake the front end when it is either entering or exiting a turn. In qualifying mode teams walk a fine line creating a setup that âfrees the vehicle upâ as much as possible without causing the driver to lose control.
MARBLES
(Also referred to as âloose stuff.â) Bits of rubber that have been shaved off tires and dirt and gravel blown to the outside of a corner by the wind created by passing vehicles comprise the âmarblesâ that are often blamed by drivers for causing them to lose control.
NEUTRAL
A term drivers use when referring to how their car is handling. When a car is neither loose nor pushing (tight).
OVERSTEER
See Loose
PIT ROAD
The area where pit crews service the cars. Generally located along the front straightaway, but because of space limitations, some racetracks sport pit roads on the front and back straightaways.
PIT STALL
The area along pit road that is designated for a particular teamâs use during pit stops. Each car stops in the teamâs stall before being serviced.
POLE POSITION
Slang term for the foremost position on the starting grid, awarded to the fastest qualifier.
PUSH
(Also referred to as âtightâ or âundersteer.â) âPushâ is a condition that occurs when the front tires of a vehicle will not turn crisply in a corner. When this condition occurs, the driver must get out of the throttle until the front tires grip the race track again.
QUARTER PANEL
The sheet metal on both sides of the car from the C-post to the rear bumper below the deck lid and above the wheel well.
REAR CLIP
The section of a race car that begins at the base of the rear windshield and extends to the rear bumper. Contains the carâs fuel cell and rear suspension components.
RESTRICTOR PLATE
An aluminum plate that is placed between the base of the carburetor and the engineâs intake manifold with four holes drilled in it. The plate is designed to reduce the flow of air and fuel into the engineâs combustion chamber, thereby decreasing horsepower and speed.
ROOF FLAPS
These flaps are sections at the rear of a race vehicleâs roof that are designed to activate, or flip up, if the air pressure flowing across them decreases. In the case of a vehicle turning backwards, the tendency for an uninterrupted flow of air is to create lift. The roof flaps are designed to disrupt that airflow in attempt to keep the vehicle on the ground.
ROUND
Slang term for a way of making chassis adjustments utilizing the race carâs springs. A wrench is inserted in a jack bolt attached to the springs, and is used to tighten or loosen the amount of play in the spring. This in turn can loosen or tighten the handling of a race car.
SETUP
Slang term for the tuning and adjustments made to a race carâs suspension before and during a race.
SHORT TRACK
Racetracks that are less than one mile in length.
SILLY SEASON
Slang for the period that begins during the latter part of the current season, wherein some teams announce driver, crew and/or sponsor changes. These days is almost all year long.
SPOILER
(Also referred to as a âblade.â) The spoiler is a strip of aluminum that stretches across the width of a race vehicleâs rear decklid. It is designed to create downforce on the rear of the vehicle, thereby increasing traction. However, the tradeoff, again, is that more downforce equals more aerodynamic drag, so teams attempt, particularly on qualifying runs, to lay the spoiler at as low an angle as possible to âfree upâ their vehicles for more straightaway speed.
STAGGER
Stagger is a concept that has largely been eliminated with the use of radial tires. It refers to the difference in tire circumference between the left- and right-side tires on the vehicle. Typically, the left-side tires would be a smaller circumference than the right-side tires to âhelpâ the vehicle make left-hand turns.
STICK
Slang term used for tire traction.
STICKERS
Slang term for new tires. The name is derived from the manufacturerâs stickers that are affixed to each new tireâs contact surface.
STOP âNâ GO (BLACK FLAGGED)
A penalty, usually assessed for speeding on pit road at the appropriate speed and stopped for one full second in the teamâs pit stall before returning to the track.
SUPERSPEEDWAY
A racetrack of one mile or more in distance. Road courses are included. Racers refer to three types of oval tracks. Short tracks are under one mile, intermediate tracks are at least a mile but under two miles and superspeedways are two miles and longer.
SWAY BAR
Sometimes called an âantiroll bar.â Bar used to resist or counteract the rolling force of the car body through the turns.
TEMPLATE
A device used to check the body shape and size to ensure compliance with the rules. The template closely resembles the shape of the factory version of the car.
TIGHT
Also known as âundersteer.â A car is said to be tight if the front wheels lose traction before the rear wheels do. A tight race car doesnât seem able to steer sharply enough through the turns. Instead, the front end continues through the wall.
TOE
Looking at the car from the front, the amount the tires are turned in or out. If you imagine your feet to be the two front tires of a race car, standing with your toes together would represent toe-in. Standing with your heels together would represent toe-out.
TRACK BAR
(Also referred to as a âPanhard bar.â) This bar locates the vehicleâs rear end housing from left-to-right under it. In calibrating the vehicleâs âsuspension geometry,â raising or lowering the track bar changes the rear roll center and determines how well it will travel through the corners. During races, this adjustment is done through the rear window using an extended ratchet. Typically, lowering the track bar will âtightenâ the vehicle and raising the track bar will âloosenâ it.
TRAILING ARM
A rear suspension piece holding the rear axle firmly fore and aft yet allowing it to travel up and down.
TRI-OVAL
A racetrack that has a âhumpâ or âfifth turnâ in addition to the standard four corners. Not to be confused with a triangle-shaped speedway, which only has three distinct corners.
TURBULANCE
Air that trails behind a race car and disrupts the flow of air to the cars behind it.
UNDERSTEER
See Tight
VALANCE
(Also referred to as âfront air dam.â) This is the panel that extends below the vehicleâs front bumper. The relation of the bottom of the valance, or its ground clearance, affects the amount of front downforce the vehicle creates. Lowering the valance creates more front downforce.
VICTORY LANE
Sometimes called the âwinnerâs circle.â The spot on each racetrackâs infield where the race winner parks for the celebration.
WEDGE
Refers to the relationship from corner-to-corner of the weight of the race vehicle. Increasing the weight on any corner of the vehicle affects the weight of the other three corners in direct proportion. Weight adjustments are made by turning âweight jacking screwsâ mounted on each corner with a ratchet. A typical adjustment for a âlooseâ car would be to increase the weight of the left rear corner of the vehicle, which decreases the weight of the left front and right rear corners and increases the weight of the right front. A typical adjustment for a âtightâ vehicle would be to increase the weight of the right rear corner, which decreases the weight of the right front and left rear and increases the weight of the left front.
WEIGHT JACKING
The practice of shifting a carâs weight to favor certain wheels.
WIND TUNNEL
A structure used by race teams to determine the aerodynamic efficiency of their vehicles, consisting of a platform on which the vehicle is fixed and a giant fan to create wind currents. Telemetry devices determine the airflow over the vehicle and its coefficient of drag and downforce.
[/align]
AERO PUSH
AERODYNAMIC DRAG
AIR DAM
AIR PRESSURE
BACK MARKER
BALANCE
BANKING
CAMBER
CAMSHAFT
CHASSIS
CHASSIS ROLL
CONTACT PATCH
DIRTY AIR
DOWNFORCE
DRAFT
DRAFTING
DRAG
ENGINE BLOCK
FABRICATOR
FIREWALL
FRONT CLIP
FUEL CELL
GROOVE
HAPPY HOUR
HANDLING
INTERVAL
LAPPED TRAFFIC
LOOSE
MARBLES
NEUTRAL
OVERSTEER
See Loose
PIT ROAD
PIT STALL
POLE POSITION
PUSH
QUARTER PANEL
REAR CLIP
RESTRICTOR PLATE
ROOF FLAPS
ROUND
SETUP
SHORT TRACK
SILLY SEASON
SPOILER
STAGGER
STICK
STICKERS
SUPERSPEEDWAY
SWAY BAR
TEMPLATE
TIGHT
TOE
TRACK BAR
TRAILING ARM
TRI-OVAL
TURBULANCE
UNDERSTEER
See Tight
VALANCE
VICTORY LANE
WEDGE
WEIGHT JACKING
WIND TUNNEL
[/align]
jeffsmonte
10-18-2006 08:40 PM
BeachBumMike
10-11-2006 01:39 AM
