Z34 oil leaks
Old May 18, 2017 | 10:59 AM
dd850's Avatar
Default Z34 oil leaks
i've got 34k miles on a newly-reman engine, and the oil is going somewhere! when i shut it off, i always smell burnt motor oil. there is NONE on the ground under the car--it's going out as i drive. i know this engine has a design flaw that causes it to leak, but what's the possibility that i could have new valve-cover gaskets or intake gasket put in, and solve this leaking?
please, someone tell me if you have had and solved this problem!!
Old May 18, 2017 | 10:41 PM
Smile
Here is a link to google that has a bunch of info with this same problem you may want to check it out.
https://www.google.com/?gws_rd=ssl#q...=1495164833952
Old May 19, 2017 | 04:11 AM
l67ss's Avatar
What motor?
