Wiring Diagram for 99 monte Carlo
Old Oct 14, 2012 | 06:27 PM
janu99's Avatar
Default Wiring Diagram for 99 monte Carlo
Not sure where I needed to post this.
If it's in the wrong place.
Admins- Please relocate.
I am having a problem with a 99 monte carlo. The speedometer and tachometer quit working. I checked all fuses and the fuse by the passenger door. I think its marked 39. Its called ignition feed fuse. or something similiar. (a 10 amp fuse) was blown. I replaced it and when I started the car, the tach moved, then promptly blew the fuse again. Does anyone have a wiring diagram that might help me locate this wire?
Any help would be greatly appreciated.
Old Oct 15, 2012 | 09:46 PM
janu99's Avatar
I had time to work on it a little this afternoon. I traced the problem to a wiring harness that connects to the brake light switch to the brake pedal.
When this connector is disconnected.
The speedo and tach work fine.
But, i have a brake trouble light on the dash.
anyone run into this before?
Old Oct 15, 2012 | 10:54 PM
zzapultimate's Avatar
I've never heard of that before. But it sounds like you are on the right track eliminating the problem down to the brake light switch. Obviously there is a short somewhere in that circuit. I'd start there and see if you can track down where the short is in the brake circuit.
9teen70monte
Oct 24, 2012 04:36 PM
Feb 9, 2012 09:31 PM
PuppetMaster
May 26, 2007 01:25 PM
SleepyEG
Dec 26, 2006 01:03 AM
moxion234
Mar 20, 2005 11:49 AM
